order of operations - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-13-2010, 04:05 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
order of operations
okay so I have finally gatherd all the parts needed to run my hybrids,( studs springs pushrods) im goingto be doing it all sometime soon, just wondering how I should go about tackling it all first, like do i do the studs first or the injectors ect. as for explinations on how to do it all I will use the search function. thanks in advance
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
post #2 of 11 (permalink) Old 02-13-2010, 05:02 PM
dinnerbooter treasurer
genuineford's Avatar
Re: order of operations
You have to pull the injectors to change the studs. So start with the studs then put the springs and push-rods in then lastly put your injectors in. Pull the glow plugs turn the engine over ( with the valve covers set in place) a couple times, reinstall glow plugs and reassemble the rest of the engine.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #3 of 11 (permalink) Old 02-13-2010, 05:32 PM
Moderator
Blowby's Avatar
While you're at it might as well inspect and/or replace your GP's, UVCH and install clips since everything is apart and the parts are not that expensive.
Blowby is offline
post #4 of 11 (permalink) Old 02-14-2010, 11:52 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
install clips? and yea i was planning on replacing the glow plugs also since im there aynway.
08 F350 Lariat
Blacked
IDP tuned SCT
post #5 of 11 (permalink) Old 03-09-2010, 03:16 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
is it realistic to think this can be done in a weekend?
08 F350 Lariat
Blacked
IDP tuned SCT
post #6 of 11 (permalink) Old 03-09-2010, 03:24 PM
Village Idiot
southmike's Avatar
as long as you have the right tools and don't loose or break nothn'
have lots of knuckle bandaids..and i get a quarter for every cuse word used durring the swap., and $1.50 if you use more then 6 in one sentence.
southmike is offline
post #7 of 11 (permalink) Old 03-09-2010, 06:22 PM
HRT Performance
HotRodTractor's Avatar
You would be a rich man if you were collecting those fees in my shop last weekend...... Damn rusty OBS trucks twisting every bolt you touch in two....
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #8 of 11 (permalink) Old 03-09-2010, 06:25 PM
All done now
Arisley's Avatar
I am doing all of that plus installing an H2E and a valve body. Plan on having it done on a Saturday, maybe a little bit of Sunday.
Arisley is offline
post #9 of 11 (permalink) Old 04-02-2010, 05:09 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
how did it all go?
08 F350 Lariat
Blacked
IDP tuned SCT
post #10 of 11 (permalink) Old 04-02-2010, 05:11 PM
All done now
Arisley's Avatar
Still waiting on headstuds and springs.
Arisley is offline
