h2e hx50?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 02-12-2010, 05:42 AM Thread Starter
99.5crewstroke's Avatar
h2e hx50??
Will the hx40 or 50 bolt up to a h2e mount? What is the benifit of a hx to the stock h2e running 238 hybrids 100% nozzles
99.5 7.3
Afe Stage 2 & Matts Tunes
Full Force 160cc Stage 1's
38r & adrenaline
6.0 tranny cooler & 6" lift
35in trail grapplers on 20in Rockstars
triple gauges with limo lights
4 buckets seats with 3 tvs & dvd
2002 F350 Dually
Stock for now
99.5crewstroke is offline
post #2 of 12 (permalink) Old 02-12-2010, 12:22 PM
Myles_S's Avatar
Re: h2e hx50??
Not too many ford guys runnin around with an HX series turbo, that i know of at least. Id stick with an H2E.
A h2e can handle those size sticks fine in stock form. As for your question im not sure
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #3 of 12 (permalink) Old 02-12-2010, 02:44 PM
cota's Avatar
Re: h2e hx50??
Back in the day the HX50 was a popular choice to run with 530 hybrids. But there wasn't much avalable back then ether.
2000,CC,4x4,auto
some bolt on stuff from Bean & BTS
Some used and some home made stuff
463hp/991tq 10/01/05 mustang dyno 10k rollers
458hp/923tq 04/14/07 dynojet dyno
490hp/1025tq 03/08/08 mustang dyno 10k rollers
03/08/08 1st runs ever, 13.5 & 13.264 @ 100.65mph screwing up both launches, 7600#'s, #2 only
cota is offline
post #4 of 12 (permalink) Old 02-12-2010, 05:02 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: h2e hx50??
a hx 50 and a h2e are basically the same. the same wheels and all interchange. the sweep on the exhaust housing is the biggest diff.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #5 of 12 (permalink) Old 02-12-2010, 07:28 PM Thread Starter
Re: h2e hx50??
they are cheaper to find and im kinda on a budget and want to have an idea on what im going to spend. Is the sweep on the exhuast housing better on one or the other or about the same?
99.5 7.3
38r & adrenaline
2002 F350 Dually
Stock for now
post #6 of 12 (permalink) Old 02-12-2010, 07:49 PM
<< wasted fuel >>
haulin99sdp's Avatar
Re: h2e hx50??
with those sticks a moded h2e will serve you very well.
haulin99sdp is offline
post #7 of 12 (permalink) Old 02-12-2010, 09:08 PM
Myles_S's Avatar
Re: h2e hx50??
A stock one would even work well
Black Ops 360
Myles_S is offline
post #8 of 12 (permalink) Old 02-12-2010, 09:36 PM
Dead Member
Marauder's Avatar
Re: h2e hx50??
Found this on the Web......
JRod
I had an hx50 - 2.8 with a 17 cm turbine housing on it. I was told that finding the 17cm housing was the most difficult part of the whole build. I do not think you are going to find a stock hx50 with a 17cm housing on it. I would bet you would have to buy the housing separately, or if you get lucky enough to get a model number off of it, you probably have to buy one new. Occasionally you could find one with a 19.5 cm housing, but the majority of the stock applications require a much larger turbine housing - 22+.
Looks like you can machine a 17cm H2E turbine housing to fit the HX50. So figure on some machining costs and the cost of the H2E housing.
It was also mentioned they are weak.......
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
post #9 of 12 (permalink) Old 02-12-2010, 10:33 PM
cota's Avatar
Re: h2e hx50??
Ouch, thats going to leave a mark.
2000,CC,4x4,auto
cota is offline
post #10 of 12 (permalink) Old 02-12-2010, 11:10 PM
Crazy Talk
Re: h2e hx50??
i am really not sure how much diff the housing is as far as bolting on, ill have to try it. i have not seen them to be weak. i was told by a builder one time that they only last one pull or they live a long life.
