Pulling Hills - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-11-2010, 11:22 AM Thread Starter
Haulin' Iron
superih's Avatar
Pulling Hills
We have a hill in the area, probably around 6% that is over 1 mile long. For the last 6 months with my truck loaded (25,000 lbs gross) I can hit this hill at 70 mph, 2000 rpm, 1200F, 17 psi, and roll across the top of it around 62 mph, 1200F, 15psi. Sometimes 3/4 of the way up the hill or as I cross the top I will get a CEL light and it will go back off about 15 miles later.
I do not have a scan gauge, but am guessing that it is running out of oil?
What do you think?
'99 F-350 CC SB Lariat 4x4 Auto -DI chip-GTP38R-BPV delete-Zoodad-Suncoast tugger trans-6.0 trans cooler-Powerstop brakes-CCV-Gauges-Exhaust-AIS Intake-Kenwood sounds-
-Traveling the Earth 300 ft at a time-
superih is offline
post #2 of 3 (permalink) Old 02-11-2010, 12:04 PM
CGMKCM's Avatar
Re: Pulling Hills
I would agree. Do you have the stock 15* HPOP? Have you tried data logging ICP?
I had similar issues and found that I had a weak pump. I bought the Adrenalin and think my problems are solved. Looking forward to Spring and hooking up the trailer and trying things out.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #3 of 3 (permalink) Old 02-11-2010, 12:16 PM
The Fireman
big_stroker's Avatar
Re: Pulling Hills
My guess would be HPOP but only way to tell would be to data log it.
Or you could spend the money on an adrenaline and ether it will fix it or it wont.
big_stroker is offline
