Fuel bowl inlet size? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 02-09-2010, 01:59 PM Thread Starter
A Ghost these days...
farm boy's Avatar
I need the size and thread pitch of the fuel inlet port of the fuel bowl. if you have one laying around, could you measure it for me? I need to buy a fitting so I can run a 3/8" or 1/2" fuel line from the fuelab to the bowl.
Thanks, Clayton.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #2 of 14 (permalink) Old 02-09-2010, 02:26 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: Fuel bowl inlet size?
Thanks, Clayton.
1/4 " pipe.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 14 (permalink) Old 02-09-2010, 02:42 PM Thread Starter
farm boy's Avatar
Thanks a million!
farm boy is offline
post #4 of 14 (permalink) Old 02-09-2010, 10:38 PM
Custom Trailer Sales
TrailerHauler's Avatar
How's the fuel bowl doing in combination with your 238's?
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #5 of 14 (permalink) Old 02-09-2010, 10:39 PM
Busy Busy
Marty's Avatar
1/4" NPT, and the outlets on the fuel bowl are 1/8" NPT.
The fuel bowl should support the 238's without issue considering Cale still has the stock fuel bowl sitting atop his BTS oil pump
Plus, I ran 13.30-13.40's on fuel with a stock fuel bowl
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 14 (permalink) Old 02-10-2010, 11:58 AM Thread Starter
farm boy's Avatar
Well, whole fuel system is torn apart right now. My stock superduty pump quit 1 day after the 238's went in. Then I threw on a Walbro to get me by. That lasted 1 day and it craped out. So now its getting a 5/8" pick-up, fuelab pump, 10ga pump wiring, and bigger fuel line from the pump to the bowl.
After I get moved into my house and get my tools moved over where I can tinker on it in the evenings, ill fab up a regulated return and a couple filter bases.
farm boy is offline
post #7 of 14 (permalink) Old 02-11-2010, 02:01 AM
Sounds like a good plan. I know whenever I get around to doing a fuel system I'll probably be doing it from scratch also, as well as ditching the fuel bowl. I like the idea, and reassurance of a pre and post fuel filter better anyway.
post #8 of 14 (permalink) Old 02-11-2010, 03:35 AM
All done now
Arisley's Avatar
Could you not put a pre pump filter in, use the factory filter and bowl for a post pump filter, bore out the factory regulator so it is just a fitting. Install a good regulator on it.
I like the idea of a stock appearing motor. Seems like it should work well, maybe I am wrong though.
Arisley is offline
post #9 of 14 (permalink) Old 02-11-2010, 04:16 AM
Snow White ran low 11's at 128.98 on a stock fuel bowl.
David Lott
post #10 of 14 (permalink) Old 02-11-2010, 12:10 PM Thread Starter
farm boy's Avatar
That's what ill be running, a 12 micron pre pump filter/base, with the stock bowl as the post pump filter. DI booster regulator for now. Upgraded lines and regulator will go in soon.
farm boy is offline
