EBPV delete how much work is it??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-08-2010, 10:53 PM Thread Starter
been thinking about doing the EBPV delete using the non ebv pedestal and the high flow outlet. Just wondering how much work is involved im thinking you have to pull the turbo and from there it shouldnt be to hard or is there more to it then what i think? any info would be appreciated Thanks
02 F-350 CC short box 4x4 106,000 miles, FFD Stage 1's PHP chip Stock, 80 DD, 65 Tow, 80 Tow, 120 Race, 4 inch exh, 6637, ITP overboost annihialater, 38R, TE Modded HPOP, EBPV Delete, Turbo Master Wastegate Controller, BTS VB, HPX Crossover line, CCV, ISSPRO gauges, 305 70 R16 Goodyear Duratrac
95 F-350 CCLB
Cat00 is offline
post #2 of 9 (permalink) Old 02-08-2010, 11:02 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: EBPV delete how much work is it???
just as simple as you said it...the hardest part is lining up the pin (pic bellow) in the Y pipe with the back of the turbo while you put the clamp on...i got it lined up and stuffed a rag between the Y and the fire wall to hold it in place while i put the clamp on....make sure to spray them clamps down good with PB blast the night before and just before you start....just take your time and have fun..
Ron's power stroke is offline
post #3 of 9 (permalink) Old 02-08-2010, 11:06 PM
peterbilt'in
Rob02F350's Avatar
hour and a half total.
3/8", 7/16", 1/2", striking pry bar, hammer. Regular and Philips screwdriver, pair of pliers, umm... flashlight and a magnet on a stick.
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #4 of 9 (permalink) Old 02-08-2010, 11:08 PM
Super Hauler!
Super_Hauler's Avatar
pretty sure the bolts that hold the turbo down to the pedistal are 13mm
Super_Hauler is offline
post #5 of 9 (permalink) Old 02-08-2010, 11:08 PM
do you work at peterbilt in Bow??
post #6 of 9 (permalink) Old 02-09-2010, 02:17 AM
Busy Busy
Marty's Avatar
Yeah but a 1/2" will work... but usually gets stuck on the bolt head a little bit.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #7 of 9 (permalink) Old 02-09-2010, 05:21 AM
Wheres the Spark Plugs?
DieselNoob's Avatar
But no one has yet to answer the OP's original question. Is this a legitimate and viable mod or just a waste of money? I am interested as well since I have a 38r with high flow outlet on the way. I didn't buy the pedastel though, it on back order and I was told I didn't need it anyways. Thoughts???
2000 Excursion, Edge CTS, GTP-38R, MBRP Stainless System, S&B Intake, 38" Toyo M/T's, 8" lift, Kodiak Grizzly Steps (THEY SUCK)
, Pioneer Z110BT.
DieselNoob is offline
post #8 of 9 (permalink) Old 02-09-2010, 05:31 AM
Busy Busy
Marty's Avatar
Remove the butterfly valve and either tap the housing and install a pipe plug or you can just put a freeze plug down in there.
As for the pedistal I gut it and use a 1/2" SAE bolt. Put a flat washer on it and then thread it through the hole and on the other side I put another flat washer, a lock washer (or a nylon locking nut) and a 1/2" nut. Tighten, replace the back cover and re-install.
Elkton, Maryland
Marty is offline
post #9 of 9 (permalink) Old 02-09-2010, 05:44 AM
<< wasted fuel >>
haulin99sdp's Avatar
if you have the pedistol and turbo off already and do not plan on useing the ebv for anything then just go head and delete it.
not a hard job to do, you should be able to get what you need for this at you local parts house. take the ped with you so you make sure and get the right size plugs.
haulin99sdp is offline
