idle control - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-08-2010, 09:57 PM Thread Starter
strokin09's Avatar
idle control
hey where can i find a aux. idle control
strokin09 is offline
post #2 of 9 (permalink) Old 02-09-2010, 06:46 PM
Village Idiot
southmike's Avatar
Re: idle control
you can buy them all over the placed as a ford aic..
there are a few diff versions one has a pto control others do not.
it can idle to a set rpm, or idle to battery charge ie 14.3 volts.
dead on accuracy....usually needs the e-brake set.
there were also diy plans floating around for a while.
southmike is offline
post #3 of 9 (permalink) Old 02-09-2010, 07:15 PM
dinnerbooter treasurer
genuineford's Avatar
Re: idle control
You can also get a high idle setting on a custom burned chip.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #4 of 9 (permalink) Old 02-09-2010, 07:25 PM Thread Starter
strokin09's Avatar
Re: idle control
im looking just to turn my idle down to a lope i know its corny but i like it will those work and there iwas the diy plans located
post #5 of 9 (permalink) Old 02-09-2010, 10:20 PM
What else?
smokyred's Avatar
Re: idle control
You can't lower the idle below stock, and that won't make it lope anyways. You can get a chip with a lope program on it, but that's just posing.
Dave
smokyred is offline
post #6 of 9 (permalink) Old 02-09-2010, 10:36 PM
Custom Trailer Sales
TrailerHauler's Avatar
Re: idle control
Can only go up from the factory set idle.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 9 (permalink) Old 02-10-2010, 02:22 AM Thread Starter
strokin09's Avatar
Re: idle control
ok thanx guys
post #8 of 9 (permalink) Old 02-10-2010, 08:56 PM
Myles_S's Avatar
Re: idle control
put a resistor in your IPC sensor.. wire it to a switch.. voilla you got lope
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #9 of 9 (permalink) Old 02-11-2010, 02:53 AM Thread Starter
strokin09's Avatar
Re: idle control
is it bad for it ??? and could u elaborate a little please
