Normal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-06-2010, 11:46 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Normal?
Here's a video of my snow stage 2. The advertised pump output is 150 psi, and I am only getting 80 out of it, almost 1/2 of what it should be. This is not going to work to with boost pressure around 65psi. I want to upgrade to the 250, but am concerned that it wont actually produce 250.
Anyone do any testing on the 250 pump?
Are they advertising dead head pressure?
907DAVE is offline
post #2 of 5 (permalink) Old 02-07-2010, 11:27 AM
TARM's Avatar
Re: Normal?
From everything I have read it will not. In fact it woudl be lucky to stay at 150.
Try CoolMist their pumps have been proven to hit the 220-250 PSI they are rated at.
TARM is offline
post #3 of 5 (permalink) Old 02-07-2010, 02:40 PM
Re: Normal?
I went w coolingmist and although I haven't check pressure, it seems to work, because the EGTs drop pretty quickly when the water comes on. CM also uses a different pump from what I was told.
99 F350 CCLB
skav is offline
post #4 of 5 (permalink) Old 02-07-2010, 06:24 PM
TARM's Avatar
Re: Normal?
CM pumps come set at a true 220 PSI and can be turned up to a full 250 psi if you have large multiple nozzles. No matter its far better than a hopped up surflow that Snow uses from everything I have seen.
TARM is offline
post #5 of 5 (permalink) Old 02-07-2010, 06:27 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: Normal?
Cool...thanks guys!
Any idea what size nozzles to run?
907DAVE is offline
