Wastegate or no? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-06-2010, 06:50 AM Thread Starter
spb_2006's Avatar
Wastegate or no?
Anybody running a 38r without the wastegate? I was considering buying a 38r with the the 1.15 exhuast housing non-wastegated, anybody running this? Any suggestions?
spb_2006 is offline
post #2 of 10 (permalink) Old 02-06-2010, 12:55 PM
powerstroke02's Avatar
Re: Wastegate or no?
i was wondering the same thing, for a daily driver, tow rig. what about boost on the highway with out being wastegated?
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
cervinis 3" cowl hood
fuel pressure-pyro-trans-boost
Full 4" exhaust
K&N fipk
Strictly diesel "bowl delete" regulated return
FASS system
cutsom built trans
stealth stage2 (big oil)
di's up pipes
38r with wicked wheel 2
6.0 trans-cooler
ccv moved
swamps modded idm
powerstroke02 is offline
post #3 of 10 (permalink) Old 02-06-2010, 12:59 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
38R with a 1.15 housing here.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #4 of 10 (permalink) Old 02-06-2010, 06:45 PM
PSN Pretender
907DAVE's Avatar
Has anyone done any back pressure testing with the 38r?
907DAVE is offline
post #5 of 10 (permalink) Old 02-07-2010, 03:28 AM
<-- GO BRONCOS
dblamp's Avatar
I think Dockboy did some BP comparisons with a 38R and an H2E a while ago.
I will see if I can find it.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #6 of 10 (permalink) Old 02-07-2010, 03:50 AM
No wastegate but stock injectors. I see 33~34psi max, no problems.
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #7 of 10 (permalink) Old 02-07-2010, 09:36 PM
Caution! May Blow Smoke
Bigcat350's Avatar
It works good for me.
Eddie
Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter,Muffler Delete,Stancore GPR, Swamps Hybrid Single Shot Injectors,DP Tuner,CCV, AIH Delete, Foil Delete, Garrett GTP38R BB Turbo with1.15 Housing,Valair, Over 400HP (SOLD)
(FOR SALE)=(SOLD)
Bigcat350 is offline
post #8 of 10 (permalink) Old 02-08-2010, 05:18 AM
<-- it's like that
Having a functional wastegate depends entirely on how much fueling you have.
For example, if you are running a 38R on stock injectors, then you have zero need for a wastegate... even with a 1.0 housing.
If you're running large hybrids and pushing well over 40 psi of boost on a 38r..... then you need a wastegate..... or a bigger turbo.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #9 of 10 (permalink) Old 02-08-2010, 07:02 PM
Myles_S's Avatar
^^ WHS
With stock fueling i see no need for a wastegate.
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #10 of 10 (permalink) Old 02-08-2010, 07:05 PM
fyrehose's Avatar
At 40psi, I am seeing about 54psi backpressure with a 1.0 housing.
2001 F-250 CC 4x4, 4" lift on 35's
Swamps Hybrids 250/30%
DP Tuner
JW Trans
Stealth Stage I
38R
PMR's
9.2 @ 73mph 1/8 mile
fyrehose is offline
