Losing Fuel Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-05-2010, 07:47 PM Thread Starter
water_junky's Avatar
I recently added a ITP regulated fuel system on my truck. When I was finished I set the fuel pressure at 65lbs. I noticed tonight it seem to have to crank a little longer to start, once it started I check the fuel pressure and it was at 40lbs. I adjusted the pressure back up to 65lbs, but the fuel pressure regulator is pretty bottomed out. So yesterday I went out and started the truck and the fuel pressure was 95lbs, I turned it back down to 65lbs and took the truck for a drive. I drove about 10 miles and checked the pressure, it was down to 50lbs. By the end of the drive (around 20 miles) the pressure had dropped to 40lbs. I'm starting to think that the fuel pump is getting weak, but the truck only has 55K on it. Anyone have any ideas?
Water_junky
2003 F350 CC 4x4 Dually,7.3L PSD[SIGPIC][/SIGPIC]
water_junky is offline
post #2 of 9 (permalink) Old 02-05-2010, 11:01 PM
Layson's Avatar
Re: Losing Fuel Pressure
Call ITP up and ask them. They will help you out.
Layson is offline
post #3 of 9 (permalink) Old 02-06-2010, 03:08 AM
PSN Pretender
907DAVE's Avatar
Did you do any tank mods?
Sounds like a weak pump or the inlet screens are getting plugged.
After sitting sediment can fall off the screens, then when you drive for a while the fuel slosh can stir it back up and plug the screens again.
If you can I would "T" in a vacuum gauge into the pump inlet, and see what it reads when pressure drops. Should be no more that 2-4 in of vacuum.
Good Luck
907DAVE is offline
post #4 of 9 (permalink) Old 02-06-2010, 01:51 PM Thread Starter
Dennis told me a few things to check and I checked those and everything looks to be just fine.
Terry
Water_junky
post #5 of 9 (permalink) Old 02-06-2010, 02:06 PM
treyloco's Avatar
Is your fuel bowl drain valve leaking.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #6 of 9 (permalink) Old 02-06-2010, 11:12 PM Thread Starter
Nope, everything is bone dry. No spots in the garage, engine valley is nice and dry.
Terry
Water_junky
post #7 of 9 (permalink) Old 02-06-2010, 11:30 PM
NorCalDiesel's Avatar
Terry
No reg return here, but I have a fuel psi guage inside the cab and over time watched to go from 60 to approx 45psi. Bought a new pump and it was still at 45psi. Pulled the tank and installed a new aftermarket fuel tank pickup and screen and got my 60 psi back. This is also supposed to help by providing fuel that is not as aerated as the OE pickup I can't remember where I got mine, maybe DieselSite.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #8 of 9 (permalink) Old 02-07-2010, 05:50 AM
<<< Power
chvyrkr81's Avatar
ITP has a 5/8ths pickup kit too.
06
02
97
74
chvyrkr81 is offline
post #9 of 9 (permalink) Old 02-07-2010, 03:35 PM
That's the one to get... been a while
