Turbo Upgrade Time - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 02-03-2010, 06:48 PM Thread Starter
3YLSYKR's Avatar
Turbo Upgrade Time
I have a nice fund and more money on the way so I wanna upgrade from the stock turbo.
I was thinking the G37R with 1.15 housing. It's a little pricey but should be a great upgrade and for ball bearing and bolt in style I have heard good reviews.
Some people have told me to not waste my money on the 38R because the gains are not worth the price when compared to bigger turbos but I want a turbo that's bolt in and ball bearing so I don't have to try to switch the rotation because I have heard that's a PITA.
I'm fairly new to the turbo side of things still so if you have any recommendations please speak up.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 25 (permalink) Old 02-03-2010, 06:52 PM
Jaydiesel7.3's Avatar
Re: Turbo Upgrade Time
iam agree with the whole bolt on part and i think 450 to 500hp rangs is good with that turbo.. i dont see why its not worth it
7.3 in progress
AFE StageII, 5" pipe, TSD Six pos chip , Cobalt three pillar gauges. Harley's, HID's and Mag-Hytec Diff Covers, 05 conv. huge want list!
Jaydiesel7.3 is offline
post #3 of 25 (permalink) Old 02-03-2010, 06:54 PM
Busy Busy
Marty's Avatar
That turbo CAN make more HP then the rods in your block can handle. And I think you meant the 38R.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 25 (permalink) Old 02-03-2010, 07:10 PM
Lovin the Tuna
RedSmokey's Avatar
You probably have PMRs. And the 38r is a nice improvement with stock injectors (not huge) and good up to some 238cc/80% sticks (are 500ish hp). I think it will work well for you if your not planning on going with over 500 hp.
2001 F250
2000 F250
RedSmokey is offline
post #5 of 25 (permalink) Old 02-03-2010, 07:18 PM
The Fireman
big_stroker's Avatar
the 38r is a great turbo and I love the one I have.
big_stroker is offline
post #6 of 25 (permalink) Old 02-03-2010, 07:18 PM
Myles_S's Avatar
What are your goals for the truck Hp wise? Do you tow? Auto or manual? What mods do you have so far?
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #7 of 25 (permalink) Old 02-03-2010, 08:48 PM
Well Hung Member
stroked's Avatar
if youre serious about a 38r pm me, i can make you a goood deal
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #8 of 25 (permalink) Old 02-03-2010, 09:55 PM
Back in Black
stroken's Avatar
Donnie - youve been trying awful hard to sell that turbo, your gonna have to sell it less then what you paid for it. lol
Im just messing with you.
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
post #9 of 25 (permalink) Old 02-03-2010, 10:16 PM
Depending on your ultimate goals, the GT38R should be a good setup. I love the one I have. (I am also running a 1.15 A/R housing) I still have my stock injectors in right now. I expected to have them swapped out to something bigger by now, but money said otherwise. It is a HAIR slower to spool up over the stock turbo at the lower RPM's with the stock injectors, but I suspect that has more to do with the size of the exhaust housing. Install was easier than I expected and literally "bolt in".
-Aaron
GreenF350 is offline
post #10 of 25 (permalink) Old 02-03-2010, 10:42 PM
Need a ride.
Strokerstooge's Avatar
Another happy camper with the 38R. Again, its all about your goals mentioned earlier. Personally I'm not going over 400 HP with mine, PMR's here and my family-daily driver tow beast...
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
