Looking for a 7.3 Intake Manifold (Aftermarket) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-02-2010, 06:47 PM Thread Starter
3YLSYKR's Avatar
I found this one by AFE that seems pretty well priced to the one you see that are 400-425 price range by cfm+.
aFe Intake Manifold 00-03 Ford Excursion 7.3L Diesel : eBay Motors (item 140377400192 end time Feb-23-10 14:29:41 PST)
What do you think about this setup? Anyone here use this?
What other intake manifolds do you use and what do you like.
I want the run down of best bang for buck parts.
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 16 (permalink) Old 02-02-2010, 07:20 PM
Well Hung Member
stroked's Avatar
Re: Looking for a 7.3 Intake Manifold (Aftermarket)
personally id save that 400 bucks and set it aside for something a little more worth it, bb turbo, maybe some sticks, i dont think youll see much gain with those things,....
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #3 of 16 (permalink) Old 02-03-2010, 05:02 AM
Need a ride.
Strokerstooge's Avatar
I agree with stroked, save your money for something else, from what I've seen and heard, these things arn't flying of the shelfs..
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #4 of 16 (permalink) Old 02-03-2010, 05:58 PM
the stryker god
i just picked up a stock one on ebay for 66 dollars, i plan on playin with it with a die grinder to free up some flow, then get it powder coated. but yeah if i was gonna spend 400 i'd get a ported housing or if you have a stock tranny maybe a bts valve body.
bruce51d is offline
post #5 of 16 (permalink) Old 02-03-2010, 06:26 PM Thread Starter
3YLSYKR's Avatar
Thanks for the insight and advice those of you who posted. I was thinking the same thing about maybe just porting the stock one on my own and having it powder coated and put the money towards my bigger turbo fund.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #6 of 16 (permalink) Old 02-03-2010, 06:29 PM
the stryker god
what mods are you currently runnin?
bruce51d is offline
post #7 of 16 (permalink) Old 02-03-2010, 07:19 PM
The Fireman
big_stroker's Avatar
Don't wast your money. I am running the stock Intake Spider and it is doing just fine.
big_stroker is offline
post #8 of 16 (permalink) Old 02-04-2010, 06:45 PM Thread Starter
3YLSYKR's Avatar
Mods are in signature.
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #9 of 16 (permalink) Old 02-04-2010, 06:59 PM
Lovin the Tuna
RedSmokey's Avatar
This is all your signature says... (look at your first post)
__________________
2001 F-250 XLT PSD
2001 F250
2000 F250
RedSmokey is offline
post #10 of 16 (permalink) Old 02-05-2010, 03:03 AM
Village Idiot
southmike's Avatar
in that case
i'd do guages intake exhuast and chip before anything else.
southmike is offline
