Replacing intake plenum boots? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 02-02-2010, 04:17 PM Thread Starter
NVJAY775's Avatar
I think my stockers have seen better days. They blow off frequently. I cleaned all surfaces thoroughly prior to reinstalling, but am having issues keeping them on. I'm thinking of picking up some new ones along with maybe some turbo clamps, instead of the stock hose clamps. Ford wants $43.00 each for stock replacements. Any suggestions on something cheaper and or better?
Thanks in advance fellas
Silver 00 4x4 ex cab lb
305 70 16's
DIY Tymar
5" stack
Modded H2E from ctperformanceinc.com
180cc AA's
DP Tuner F5
Full Jimmy Converse trans / converter
6.0 trans cooler
NVJAY775 is offline
post #2 of 22 (permalink) Old 02-02-2010, 04:22 PM
moore20017.3's Avatar
Re: Replacing intake plenum boots?
Any truck shop will have stainless T-Bolt clamps for about $7-10 each. Most of them will have good silicone boots too.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #3 of 22 (permalink) Old 02-02-2010, 05:45 PM
CGMKCM's Avatar
Several sponsors sell replacement hoses and clamps. Here is one example.http://www.dieselsite.com/index.asp?...ROD&ProdID=133
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #4 of 22 (permalink) Old 02-02-2010, 07:24 PM
Well Hung Member
stroked's Avatar
ditto, i and a few others i know have the dieselsite kits, good stuff
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #5 of 22 (permalink) Old 02-02-2010, 11:10 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Have you inspected your intake plenums for proper roundness. What I mean is if you have over tightened the clamps it will crush the intake plenum and make it out of round. So your worn oily boots and the out of round plenum might be the problem. These inserts here http://www.dieselorings.com/index.ph...&cat=9&group=6 make it so you can tighten them down to keep them from blowing off and also prevents the plenum from crushing. I am running the boot kit from Dieselsite but i am not using the plenum insert as I just found them today. Dave at Swamps has mentioned welding in some short pieces of exhaust tubing to serve as the same purpose to keep the plenum from crushing.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #6 of 22 (permalink) Old 02-03-2010, 12:01 AM Thread Starter
NVJAY775's Avatar
Thanks for the input. I do like diy stuff, so I'm going to pick up some t-clamps and some hose from delta rubber (localy) and see how that goes. If I fail (which I hope not) I'll do the kit from dieselsite. I'm liking those inserts though. I didn't check for roundness when I had it apart last. I'd like to do some inserts at the same time.
Thanks again!
Jay
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #7 of 22 (permalink) Old 02-03-2010, 01:21 AM
Village Idiot
southmike's Avatar
Steal the ol lady's hairspray and give them a squirt when you do the change just for a lil extra bite.
southmike is offline
post #8 of 22 (permalink) Old 02-03-2010, 04:30 AM Thread Starter
NVJAY775's Avatar
Will do. Thanks for the tip there.
305 70 16's
DIY Tymar
5" stack
180cc AA's
DP Tuner F5
6.0 trans cooler
NVJAY775 is offline
post #9 of 22 (permalink) Old 02-03-2010, 04:57 AM
Need a ride.
Strokerstooge's Avatar
If your boots are shot, I got these from this place Riffraff Diesel: RDP Complete Aramid Boot Kit , they're a strong silicon and just all around the best I've seen. T clamps are 5.00 bucks too..
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #10 of 22 (permalink) Old 02-03-2010, 07:32 AM
DJM
DJM's Avatar
Im gona be replacing my boots too and Im gona go with the ones from Riff Raff $109 for all 6 boots seems like a good deal I could see the diesel site ones if you were pushing big boost levels
01 CC Auto
DP F6 60econ 80tow 80econ 120race
6" lift 37" tires
HPX
RiffRaff FRX
WW
AFE Big Boost
CCV
FS 2500 Filter
DJM is offline
