H2E vs QSSB - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 02-02-2010, 08:59 AM Thread Starter
Powersmokesd's Avatar
H2E vs QSSB
Lookin at buyin a new turbo, wondering which of these two is better? Is the QSSB worth the 500 more? Let me know what you think.
Rollin' Black Smoke!
Powersmokesd is offline
post #2 of 18 (permalink) Old 02-02-2010, 11:54 AM
Pulling sled for hire
ParkerFly's Avatar
Re: H2E vs QSSB
What horsepower level are you at or going to be at?
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #3 of 18 (permalink) Old 02-02-2010, 06:57 PM Thread Starter
Re: H2E vs QSSB
Got stage 2's on a stock turbo now. So its living on borrowed time. Will go with a hybrid 238 or 250 some day.
post #4 of 18 (permalink) Old 02-02-2010, 07:09 PM
bobvillaoftn's Avatar
Re: H2E vs QSSB
OUCH!!!! might i ask why? i am wanting to go 238's so thisll be good for me.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #5 of 18 (permalink) Old 02-02-2010, 07:22 PM
Well Hung Member
stroked's Avatar
Re: H2E vs QSSB
38r would be ideal for that size injectors, i know i love the way my 38r and 1.15 housing act with my 238/80%'s, (psssst its for sale)
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #6 of 18 (permalink) Old 02-02-2010, 10:54 PM
Re: H2E vs QSSB
I wouldn't mess with a drop in at that level. No room to grow. I have a qssb with AC's and couldn't be happier. 38psi pretty easy and cleans them pretty well. Don't think you can go wrong with either at sea level. The s300/400 may be better for modding later but I don't have any experience personally so I won't say. Stock H2e or Qssb are both maxed over stage 2's but are often pushed over that but it depends on other factors and goals. Altitude, trans, towing, pulling, dd, tuning, and taste all determine which turbo will make you happy. Will a stocker work, yes, will a sledgehammer work, yes. Stock H2e or qssb is more of a question of stick or auto and how fast you think the turbo should spool. I drove a truck similar to mine except s2's and bb and spool was the same as mine AC and qssb. Your call. I like mine and couldn't be happier but I you won't be dissapointed with h2e either.
brickhead is offline
post #7 of 18 (permalink) Old 02-03-2010, 12:48 AM
TARM's Avatar
Re: H2E vs QSSB
The QSSB with a kit from Carlson would be my choice. You then have room to grow. You can upgrade to the GQSSB which will given you enough flow for mid 500's+ with the correct other upgrades. The upgrade to the gqssb is a perfect match for 238/259 hybrids when you are ready. The qssb is very well matched to your stage II's you have now. Give Zane at WOP a call.
TARM is offline
post #8 of 18 (permalink) Old 02-03-2010, 12:50 AM
<< wasted fuel >>
haulin99sdp's Avatar
Re: H2E vs QSSB
the h2e and the qssb are both good turbos from what i hear and if ever needed both can be moded if you decide to grow. vs the 2, i cant say because i havent run either one of them but alot of guys like their moded h2e and i believe the qssb is a step up from a standered h2e.
haulin99sdp is offline
post #9 of 18 (permalink) Old 02-03-2010, 08:03 AM Thread Starter
Re: H2E vs QSSB
Thanks guys for all the input. I think im going with an S300 in a 66mm trim. I need something I can throw 250cc hybrids at soon. Going to run my stage 2's for a bit till I can afford to turn my stock injectors into hybrids.
post #10 of 18 (permalink) Old 02-03-2010, 08:05 AM
<< wasted fuel >>
Re: H2E vs QSSB
i will be running similier injectors with an s300 based turbo in a few days...it should be a sweet setup!!
