38R - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-01-2010, 02:26 AM Thread Starter
powerstroke02's Avatar
38R
Can I put my gtp 38R turbo on my truck with out puttin injectors in it. I have some injectors just need to get the money together to get the chip reburned.
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
cervinis 3" cowl hood
fuel pressure-pyro-trans-boost
Full 4" exhaust
K&N fipk
Strictly diesel "bowl delete" regulated return
FASS system
cutsom built trans
stealth stage2 (big oil)
di's up pipes
38r with wicked wheel 2
6.0 trans-cooler
ccv moved
swamps modded idm
powerstroke02 is offline
post #2 of 17 (permalink) Old 02-01-2010, 02:27 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: 38R
Yes you can.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is online now
post #3 of 17 (permalink) Old 02-01-2010, 02:29 AM
Don't EFN worry about it
Aljay's Avatar
Re: 38R
Whatabudro has a 38r on stock sticks his truck runs damn good.
Tuned by T Wildman
Aljay is offline
post #4 of 17 (permalink) Old 02-01-2010, 03:20 AM
Need a ride.
Strokerstooge's Avatar
Re: 38R
Got one on mine, my truck runs great with it, like you, waiting to scrounge up some cash for sticks then you'll fully appreciate that 38r, put it on..
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #5 of 17 (permalink) Old 02-01-2010, 03:29 AM Thread Starter
Re: 38R
Ok thanks. I already have the sticks just need to get the chip reburned.
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #6 of 17 (permalink) Old 02-01-2010, 03:44 AM
Need a ride.
Re: 38R
Opps, re-read your post, gotya..
post #7 of 17 (permalink) Old 02-01-2010, 10:19 AM
dinnerbooter treasurer
genuineford's Avatar
Re: 38R
What do you have for sticks? A couple of us usually go to the great lakes dragaway opener every year. You should meet up with us there if you can. It is race for the price of admission that day. I will probably send out a PM when it gets closer and put a post up in the local section.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #8 of 17 (permalink) Old 02-01-2010, 10:38 AM Thread Starter
Re: 38R
diesel innovations hybrids 530's
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #9 of 17 (permalink) Old 02-01-2010, 04:46 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: 38R
My wifes Excursion runs a 38r with a 1.15 exhaust housing...
She loves it!
Joe
CSIPSD is offline
post #10 of 17 (permalink) Old 02-01-2010, 05:30 PM
Bigtimearcher's Avatar
Re: 38R
The opener is getting close!!!!! A couple more months and it's go time!
2009 Ford F250 CCSB Lariat. H&S Minimax tuner, AFE 4" dp back exhaust, AFE Stg 2 PG7, EGR Delete
Bigtimearcher is offline
