fuel pump dowel pin fell in engine... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-01-2010, 02:13 AM Thread Starter
hey guys, i was replacing my pump and the neck snapped off in the block ,i sweated balls but i got that out, then the pin fell out into and below the cam, does any one have a diagram of the engine? i want to know what my options are right now. i know someone did a really nice right up of a rebuild of a stroker not too too long ago and it showed a nice picture of the cam area opened up and thats exactly what i need right now
some one please help!
rideracelivemx7 is offline
post #2 of 5 (permalink) Old 02-01-2010, 02:32 AM
What else?
smokyred's Avatar
Re: fuel pump dowel pin fell in engine...
By pin do you mean the fuel pump lifter?
If that's what fell in, if you heard it go splash into the oil, and then hit the bottom of the pan, you should be OK, it won't go anywhere.
Dave
smokyred is offline
post #3 of 5 (permalink) Old 02-01-2010, 02:40 AM Thread Starter
no it sounded like it hit a platform of some sort, no spash sound, what is directly under the cam? is it seperated by a vally of some sort? im trying to find a dang picture and itsnot working!
post #4 of 5 (permalink) Old 02-01-2010, 02:52 AM
Mike's Diesel Performance
sick97psd1's Avatar
Send a message via AIM to sick97psd1
Good luck, I had the same thing happen but I was able to get a pair of vice grips on the lifter and wiggle it back and forth out. If that wouldnt have happend I would have been in the same situation you are in.
734-385-4208
sick97psd1 is offline
post #5 of 5 (permalink) Old 02-01-2010, 10:28 AM
dinnerbooter treasurer
genuineford's Avatar
It is pretty open to the oil pan from the cam. There is a "platform" or splash guard in the oil pan that it may have landed on. Here is a picture of the oil pan off of a SD, the OBS ones are slightly different but very close.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
