engine fan - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-01-2010, 12:29 AM Thread Starter
engine fan
i have a 2000 f 350 and it broke on me while removing the water pump. my question is a 95-03 should work also right is is it a little different. let me know what yall think
SmokeStacker
corywhitedually2000 is offline
post #2 of 8 (permalink) Old 02-01-2010, 02:31 AM
Re: engine fan
95-03 what?
I would think that it would have to be for a diesel. If you get the wrong pitch blade then you will have over heating issues.
1997 F350 7.3L OBS (Old Big and Slow)
3" Downpipe (cat delete 364.5 days a year)
Custom tunes by ME
AFE Intake
Rebuilt Transmission(The works-Tripple disk TQ, All Steel insides)
Old Big and Slow is offline
post #3 of 8 (permalink) Old 02-01-2010, 10:50 AM
dinnerbooter treasurer
genuineford's Avatar
Re: engine fan
The OBS fans are metal, at least our 94.5 is. I don't think it will fit on my SD water pump but I could be wrong.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #4 of 8 (permalink) Old 02-01-2010, 11:59 AM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: engine fan
I dont believe there even close to being the same.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #5 of 8 (permalink) Old 02-01-2010, 03:11 PM
Junior Mint
Re: engine fan
I have a spare fan I removed off of my 1999 SD about 1 year ago to install an electric fan set up.
Want to buy it? Have the shroud as well.
I'm officially...Stroke-less.
Suns_PSD is offline
post #6 of 8 (permalink) Old 02-01-2010, 09:52 PM Thread Starter
Re: engine fan
i dont need the shroud just the fan. how much for just the fan?
SmokeStacker
post #7 of 8 (permalink) Old 02-01-2010, 10:05 PM
Junior Mint
Re: engine fan
Please respond back thru pm.
50 cents on the dollar for the least expensive new one you can find online plus shipping.
Suns_PSD is offline
post #8 of 8 (permalink) Old 02-02-2010, 01:45 AM
Oordski
Oordski's Avatar
Re: engine fan
Can you run an electric setup with the regular fan? Mine kicks out in a hard pull high RPM...2 different fan hubs same thing. Or is it the fan blades getting hot and flattening out?
02 7.3 L Powerstroke 4 door with DP Tuner, Wicked Wheel, 1.0 Housing, Terminator pumps, Single Shot AC Injectors, BD Converter, Billy Built Tranny, 4.30 Gears, 325/65R18 Tires, and For Mama:Captain Heated Seats all the way around and 2DVD Screens, In dash GPS. Newly added: 51 gallon Titan fuel tank, Airdog II, CCV, QSSB from Wideopen Performance
Oordski is offline
