What would you do??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 02-01-2010, 12:02 AM Thread Starter
Wheres the Spark Plugs?
DieselNoob's Avatar
Hi guys, once again I am hoping you can point me in the right direction here. My rig is a 2000 Ex with the 7.3 and 136,000 on the clock now. The truck is lifted 8" and rides on 38x15.50's with 4.56 gears. I have added a S&B Intake, MBRP 4" Stainless System and an Edge CTS Tuner that I keep on level 2. I added all of these parts at once and immediately started experiencing surge at anything above 10psi and EGT's of over 1200 degrees anytime I head up any kind of a hill or put some pedal to it on the highway. Where would you go from here to correct this? Should I throw a new/better turbo and intercooler at it? I'm at a loss at the moment. As always, thank you in advance for all the help and knowledge.
2000 Excursion, Edge CTS, GTP-38R, MBRP Stainless System, S&B Intake, 38" Toyo M/T's, 8" lift, Kodiak Grizzly Steps (THEY SUCK)
, Pioneer Z110BT.
DieselNoob is offline
post #2 of 37 (permalink) Old 02-01-2010, 12:05 AM
Stroker67's Avatar
Re: What would you do???
Custom tunes would help, I'm sure more 7.3 guys will chime in.
Stroker67 is offline
post #3 of 37 (permalink) Old 02-01-2010, 12:11 AM
an ats housing or wicked wheel will solve your surge.. as for the egt's not to sure but custom tunes will reduce your egt's by a bit bc they can be tuned to your truck vs. ur edge is tuned to everyother truck like it.. IMO
2006 f-250 ext cab swb, 127,000mi, Egr delete, 4" tb exhaust, edge juice w/ cs.
Ryan
dp_stroker is offline
post #4 of 37 (permalink) Old 02-01-2010, 12:13 AM
wheres the fat chicks?
PowerstrokeR00's Avatar
ww and custom tunes as well
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #5 of 37 (permalink) Old 02-01-2010, 12:16 AM Thread Starter
DieselNoob's Avatar
Whats the normal life expectancy of a stock turbo? Is it a wise idea to spend the $450 on a ATS Housing (to install on a 136,000 mile turbo) or just suck it up and buy a new turbo all together. Are you guys still running your stock intercoolers or have you upgraded?
, Pioneer Z110BT.
post #6 of 37 (permalink) Old 02-01-2010, 12:17 AM
<< wasted fuel >>
haulin99sdp's Avatar
custom tunes and a 38r or a van turbo.
haulin99sdp is offline
post #7 of 37 (permalink) Old 02-01-2010, 12:22 AM
well, i might be alone on this one but i'm still running stock intercooler and have a stock charger with a ww with over 200,000 miles on it. and still doesn't have any play in the shaft....knock on wood
Ryan
post #8 of 37 (permalink) Old 02-01-2010, 12:27 AM
NevrKnow's Avatar
Ditch da edge.
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #9 of 37 (permalink) Old 02-01-2010, 12:31 AM Thread Starter
DieselNoob's Avatar
Ditching the EDGE would be a last effort for me. Its way to convenient to have access to all the reading I could need without having to buy a ton of gauges. Im not looking for 600 horse, Im just looking to make what I have now usable. I wouldnt consider 1100 plus temps with no load behind me usable but I also dont claim to know near what you guys do as well. Whats the difference between the 38r and the 42 series? Is it worth the extra money?
, Pioneer Z110BT.
post #10 of 37 (permalink) Old 02-01-2010, 12:44 AM
Austinj427's Avatar
That 42r will be too much turbo for stock sticks. You could get custom tunes, and keep the edge just for the gauges.
I can't believe no one has said anything about it, but do you have a boost leaks? Have you checked all your boots for cracks, loose clamps, etc? Also the uppipes that lead to the turbo from the exhaust manifold are know for leaking.
As for the turbo, have you check to see if there is any play in it? Side to side is rebuildable, in and out, and you need a new turbo.
thats all I got.
Austinj427 is offline
