DP F5 changing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-31-2010, 02:57 PM Thread Starter
Send a message via AIM to Barnbuilder
DP F5 changing
On the way home from firestation this morning my chip changed settings on me twice. Anyone have this happen? Luckily it was right after I had started out as we had alot of ice on the roads.
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #2 of 4 (permalink) Old 01-31-2010, 03:12 PM
Re: DP F5 changing
mine did the same thing jody did a reflash and it took care of it
99oilburner is offline
post #3 of 4 (permalink) Old 02-01-2010, 04:15 AM
Need a ride.
Strokerstooge's Avatar
Re: DP F5 changing
Never happen here, like mentioned above, give Jody a call..
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #4 of 4 (permalink) Old 02-01-2010, 06:09 AM
Dead Member
Marauder's Avatar
Re: DP F5 changing
Check the connection at the chip as well as the LED switch.
I've had mine loosen over time and wiggle loose.The numbers on the switch start scrolling when I would hit a good bump on the road. I tweaked the prongs to tighten things up on the switch/plug and have had no issues since.
Check the plug for firmness of connection.......
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
