hpop install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-27-2010, 10:52 AM Thread Starter
powerstroke02's Avatar
hpop install
Do u have to get the chip reburned for big oil? I have a dp tuner
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
cervinis 3" cowl hood
fuel pressure-pyro-trans-boost
Full 4" exhaust
K&N fipk
Strictly diesel "bowl delete" regulated return
FASS system
cutsom built trans
stealth stage2 (big oil)
di's up pipes
38r with wicked wheel 2
6.0 trans-cooler
ccv moved
swamps modded idm
powerstroke02 is offline
post #2 of 11 (permalink) Old 01-27-2010, 01:48 PM
Re: hpop install
You should..
email:
Website:
OBSWIZ is offline
post #3 of 11 (permalink) Old 01-27-2010, 02:20 PM
The Fireman
big_stroker's Avatar
Re: hpop install
To take advantage of it yes you should get a reburn.
big_stroker is offline
post #4 of 11 (permalink) Old 01-27-2010, 07:27 PM
Village Idiot
southmike's Avatar
Re: hpop install
which big oil system is it?
southmike is offline
post #5 of 11 (permalink) Old 01-27-2010, 08:27 PM Thread Starter
Re: hpop install
stelth stage 2. but do i have to get it reburned
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
post #6 of 11 (permalink) Old 01-27-2010, 08:49 PM
Slated4Greatness's Avatar
Re: hpop install
As was stated earlier, if you want to take advantage of your new found volume and pressure a reburn will be needed unless you have an F6 then it is downloadable (←That word doesn't look right) directly to the chip.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #7 of 11 (permalink) Old 01-28-2010, 03:53 AM
All done now
Arisley's Avatar
Re: hpop install
It will work, yes. It will not hurt anything. You will notice a difference. But when you save up and get a reburn, you will notice even more difference.
Arisley is offline
post #8 of 11 (permalink) Old 01-28-2010, 12:56 PM
Village Idiot
southmike's Avatar
Re: hpop install
You can pinch some pennies for a bit.
Talk to yor tuner to see just what you will gain,
In fact talk to a few maybe a good time to change if you have to buy reburns.
post #9 of 11 (permalink) Old 01-28-2010, 04:59 PM
TARM's Avatar
Re: hpop install
Could it not over shoot ICP if not tuned for it. I am going off looking at what happened with Bill PHP when he did the OD Adrenaline test on a bascially stock chipped motor. Again my knowledge is very limited but thought that may be pertinent. He spiked to 3600 IIRC and some other things as well.
TARM is offline
post #10 of 11 (permalink) Old 01-28-2010, 08:21 PM Thread Starter
Re: hpop install
i noticed a big difference allready. alot more power,less smoke and no more bogging with the tq locks up, also faster starts.
2002 psd,4x4 ECSB
DP-TUNED
4" lift 35" tires
3.73 gears
Full 4" exhaust
K&N fipk
FASS system
cutsom built trans
di's up pipes
6.0 trans-cooler
ccv moved
swamps modded idm
