CCV4500 Experience and/or Opinions??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 01-26-2010, 09:07 PM Thread Starter
hotstik's Avatar
With the upcoming smog BS here in CA, I'm looking at going back to a closed crank case setup on my daily driver. However, I have no desire to deal with the oily mess that can result.
So, I'm considering going with a Racor CCV4500.
I was wondering who is running, or has run, the CCV4500, and what is/was your experience with it?
Thanks!
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #2 of 25 (permalink) Old 01-26-2010, 09:26 PM
jeromejcp's Avatar
Re: CCV4500 Experience and/or Opinions???
I believe that is the same one di sells. I had one and it worked well so long as you changed the filter every oil change. I was lazy and cheap (the filters are hard to find and cost 36 bucks). The red indicator didn't work for me. I hate emissions tests, thank god I don't have to deal with them here.
Best of luck
JP5
00 F350 CC LB 4x4 auto. Nitto Terra 285 75 r16 E, Dynatrac free spin hubs, ccv, rancho stabilizer, centramatics, upgraded GPR, DB starter, 2.0 ga pos cable, matching 5th rim, 6637, 4" SS magnaflow, CPR, Scan Gauge, Mag Hytech.
USN VBSS, Burn sink or take a-prize.
jeromejcp is offline
post #3 of 25 (permalink) Old 01-26-2010, 09:45 PM
aklim's Avatar
How difficult would it be to get the pipe for the CCV and keep the old setup. That way you can switch back at will before the test.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #4 of 25 (permalink) Old 01-26-2010, 10:11 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Here is the CCV kit I am using. I got it from NC Hornet. I know it is a bad picture. http://www.stealth-automotive.com/in...roduct_id=1372
BD Diesel Performance also has there own version of a similar Racor kit.
BD is a sponsor and so is Stealth Automotive.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #5 of 25 (permalink) Old 01-26-2010, 10:18 PM
Haters Gonna Hate
Fordfreak4life's Avatar
would it be possible to return it direct into the intake manifold instead of oiling up or charge air coolers? or possibly dump it into the exhaust? just food for thought idk how that would affect emissions dumping it into the exhaust though
Fordfreak4life is offline
post #6 of 25 (permalink) Old 01-26-2010, 10:19 PM
aklim's Avatar
People have dumped it into the exhaust and noticed that the crankcase pressure is higher.
aklim is offline
post #7 of 25 (permalink) Old 01-26-2010, 10:21 PM Thread Starter
hotstik's Avatar
It wouldn't be difficult at all. In fact, I still have the stock setup sitting here somewhere, and I have the ITP kit on my truck.
Unfortunately, venting to the atmosphere (which I think is the best option) still results in a hazy cloud behind the truck (if weather conditions are condusive) when at idle. The stinky haze can piss off the tree huggers nearly as bad as belching a bunch of black smoke. I'm trying to keep it clean.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #8 of 25 (permalink) Old 01-26-2010, 10:22 PM
Just move out of commifonia
2000 F-350 ccsb 4x4: DIY intake, 4 inch straight, Tuning by [email protected]
99 tacoma V6 5sp 4x4: Chaos/DR mid travel kit, F/R glass, 33x12.50 MTR's---Sold
08 F-150 Lariat Screw 4x4:---Sold
2005 F-250 Lariat ccsb 4x4 auto: All stock for now
Stroke00 is offline
post #9 of 25 (permalink) Old 01-26-2010, 10:24 PM Thread Starter
hotstik's Avatar
BD Diesel Performance also has there own version a similar Racor kit.
The BD kits uses the CCV3550 which I don't think will flow enough for my application. It's a nice kit though.
And...I've heard too many negatives about the NCHornet kit. In particular, a number of people have noted that it does not catch all the oil.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #10 of 25 (permalink) Old 01-26-2010, 10:27 PM Thread Starter
hotstik's Avatar
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
