TS Burner Issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-26-2010, 03:07 AM Thread Starter
Layson's Avatar
TS Burner Issues
I have an old DP tuner rotary style TS position chip with old DP tunes. I am trying to put new tunes on it with a TS burner. For some reason it won't work. Keep getting a "not a mult-position module" error? My computer is communicating with it since I can get it to beep at me... Is this old DP tuner style chip not burnable? Or am I doing something wrong?
Any idea's anyone?
Layson is offline
post #2 of 7 (permalink) Old 01-26-2010, 03:10 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: TS Burner Issues
I have been told that the dp tuners are in a differant format or have a code on them or somthing that wont let you burn them. I believe you can send them to ts and have them reformated
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #3 of 7 (permalink) Old 01-26-2010, 03:15 AM Thread Starter
Layson's Avatar
When I selected 1 position it would come back with some type of formatting error... hmmm... you may be right. So I can't reformat the chip with this burner... that sucks...
Layson is offline
post #4 of 7 (permalink) Old 01-26-2010, 03:17 AM
<< wasted fuel >>
haulin99sdp's Avatar
i think the dp tunes are locked with a code or somthing.
problly a diffrent format as well. im not ahure if ts can reformat them anymore (had problems with reformating a bd chip) but im shure there is someone that can.
haulin99sdp is offline
post #5 of 7 (permalink) Old 01-26-2010, 03:35 AM
Sponsor
CLIFORD3's Avatar
your chip is locked you would need a new blank chip or a burner from dp
Jason Murff
832-73-MURFF
Murffracing.com
Proud Sponsor of Race For The Warriors
CLIFORD3 is offline
post #6 of 7 (permalink) Old 01-26-2010, 11:55 AM
The Fireman
big_stroker's Avatar
The chip needs reformatted. You can send it in and have this done.
big_stroker is offline
post #7 of 7 (permalink) Old 01-26-2010, 03:14 PM Thread Starter
Layson's Avatar
Thanks guys... Now I just gotta get it done!
Layson is offline
