comp 910's or something else.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-26-2010, 02:20 AM Thread Starter
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
hi guys, trying to pick a vavle spring...
i did a search and read through a few threads and now i'm fairly confused
i was under the impression that the 910's were the way to go. but its seems around 500 is their limit?
the setup is going to be as follows:
250 cc hybrids
fuel system
either a modded h2e or the the new GQSSB
arp studs
pushrods
tunes(obviously)
will that setup on a hot tune be to much for the 910s?
what are my other options, with out having to pull the heads for machine work?
CCLB with some stuff done .....
BigRed97 is offline
post #2 of 12 (permalink) Old 01-26-2010, 02:24 AM
Plays with Motors
Machinist's Avatar
Re: comp 910's or something else..
Comp 910 springs - Page 2 - Powerstroke Nation
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #3 of 12 (permalink) Old 01-26-2010, 02:29 AM
<< wasted fuel >>
haulin99sdp's Avatar
the comp cam 910's should do it just fine, no machining required.
haulin99sdp is offline
post #4 of 12 (permalink) Old 01-26-2010, 02:39 AM Thread Starter
The Oracle
BigRed97's Avatar
Originally Posted by Machinist View Post
thats actually the thread that confused me....maybe i just dont under stand what is being said
the 910s will be ok for 450-500ish?
I know the 910s dont need machining, i was wondering if there are other(maybe better) options, that also dont require machining?
BigRed97 is offline
post #5 of 12 (permalink) Old 01-26-2010, 02:42 AM
<< wasted fuel >>
the 910's will be good upgrade for that power level and over, if iirc, there was a few 600hp+ trucks running the 910's without issue's.
i
post #6 of 12 (permalink) Old 01-26-2010, 02:53 AM
aggie's Avatar
While the 910s are not much stiffer than stock, i think they are a decent upgrade, especially if the current oe units in the truck are a little weak. We have ran the exact same setup you are referring to in many trucks and not had a valve float issue yet. The h2 setup actually helps a bit as they typically have a lower drive ratio than a 38r setup.
on edit..i think its a decent worthwile upgrade for the setup you mentioned esp if youll have custom tuning to take your mods into consideration. the springs are 85 bucks from summitt and i think its worth the money. However on a race setup or high hp build i dont beleive they have any place.
[SIGPIC][/SIGPIC]
aggie is offline
post #7 of 12 (permalink) Old 01-26-2010, 03:26 AM Thread Starter
The Oracle
BigRed97's Avatar
cool, thats what ineeded to know, thanks guys!
BigRed97 is offline
post #8 of 12 (permalink) Old 01-26-2010, 08:44 AM
OBNOXIOUS MOTORSPORTS
alterdst8's Avatar
Send a message via Yahoo to alterdst8
i agree either go with hypermax springs for a good top class set. seat pressure is much higher than 910s but for what your doing a set for of 910 16s is good. i say have a talk with nate the master machinist or aggie they will set you straight get a modded H2 i turned mine into something obnoxious
02 c/c lariat 4x4 DI studs, Rosewood BIG OIL, 76mm/22cm XXXH2Evil, some fuel, C2 gauges, tru trac F/R 4.30 gears, custom shafts, Stallion TC, Fully built Suncoast, mag hytech pan, 5" pipe, 25k gooseneck hidden hitch , 2 motors, STILL on pmrs in one
Mitch in Mayetta Ks my turbo sponsor
OBNOXIOUS DIESEL built build
alterdst8 is offline
post #9 of 12 (permalink) Old 02-04-2010, 03:42 PM
Buffalo Diesel
What about putting shims with the 910s?
2000 F350 CC LB - 250cc 200% - Matt Tuned - 9" Lift - 38" Extreme ATs - Vegistroke
Jack_Toepfer is offline
post #10 of 12 (permalink) Old 02-04-2010, 03:49 PM
Busy Busy
Marty's Avatar
250 cc hybrids
fuel system
arp studs
pushrods
tunes(obviously)
Looks like I didn't get that message
You'll be fine
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
