piston ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-25-2010, 11:22 PM Thread Starter
wampaku's Avatar
piston ?'s
if i remember correctly, i read on here that doing something to the piston bowl helps relieve something. can someone explain a little more on this.
1999.5 f350 xlt 4x4-afe stage ii intake, wicked wheel, 4" hog performance exhaust, dp tuner chip, 8" lift with 40's, arb's front and back, etc.
2002 excursion limited 4x4- afe stage ii intake, 4" hog performance exhaust, and dp tuner f5 chip
2005 vw jetta tdi- q loader chip for now
wampaku is offline
post #2 of 10 (permalink) Old 01-26-2010, 12:04 AM
JHill's Avatar
Re: piston ?'s
are you thinking radiusing (sp) the lip on the bowl and hot spots
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 10 (permalink) Old 01-26-2010, 12:26 AM
Village Idiot
southmike's Avatar
Re: piston ?'s
Your not talking about where they are altering them to lower compression a bit are you.
southmike is offline
post #4 of 10 (permalink) Old 01-26-2010, 12:55 AM
Plays with Motors
Machinist's Avatar
Re: piston ?'s
Bowl work for lowering CR??? - Powerstroke Nation
Lowering Compression - Powerstroke Nation
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #5 of 10 (permalink) Old 01-26-2010, 01:24 AM
Don't EFN worry about it
Aljay's Avatar
Re: piston ?'s
All I will say is the reduced mahles suck to start in 30* weather so think about it on a daily driver mine has been parked more than driven the last few weeks.
Tuned by T Wildman
Aljay is offline
post #6 of 10 (permalink) Old 01-26-2010, 01:44 AM
Dairy Mechanic
Magnum PD's Avatar
Re: piston ?'s
I got a set of .010 decked pistons that are .020 over. Any advice for me on things I should do to them let me know. Thinking about ceramic coating. Shooting for around 500 hp.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #7 of 10 (permalink) Old 01-26-2010, 02:07 AM Thread Starter
wampaku's Avatar
Re: piston ?'s
so what is the best compression ratio? what is stock? is doing this to the pistons just for high hp? just trying to learn something.
wampaku is offline
post #8 of 10 (permalink) Old 01-26-2010, 02:09 AM
Dairy Mechanic
Magnum PD's Avatar
Re: piston ?'s
Ask golfer.
post #9 of 10 (permalink) Old 01-26-2010, 02:21 AM
Plays with Motors
Machinist's Avatar
Re: piston ?'s
You have other issues, or the compression was set much lower than intended. What was the actual measured compression at build time? Measured piston protrusion?
Setting compression by using a lower compression height piston rather than bowl work will make a lazy motor.
2011 335i M-Sport
post #10 of 10 (permalink) Old 01-26-2010, 02:28 AM
Aljay's Avatar
Re: piston ?'s
Everything was left alone. Doesn't seems to lazy !Machinist this was thrown together to get my truck up where I was.
Tuned by T Wildman
Aljay is offline
