early 99 turbo set up in a 96? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-25-2010, 09:39 PM Thread Starter
I like turtles
NE-STROKE's Avatar
Hi
I am putting a h2e in my truck. A friend of mine was wondering if it would help to put my stock set up in his 96 if he finds a intercooler?
Are the e-99s turbo better? Is there anything else he would need?
How much is all my stock stuff been know to go for?
NE-STROKE is offline
post #2 of 12 (permalink) Old 01-26-2010, 12:01 AM
JHill's Avatar
Re: early 99 turbo set up in a 96?
there about the same size and = flow. seem like alot of work for little if any improvment. I could be wrong- might try posting in the OBS Forum if you dont get many answers here.
seen complete 99+ go for anywere from $200 -$500.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 12 (permalink) Old 01-26-2010, 12:11 AM
Village Idiot
southmike's Avatar
seems like a lot of obs guys snatch up e99 spyders,
got to be a demand for them for some model.
southmike is offline
post #4 of 12 (permalink) Old 01-26-2010, 01:31 AM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
pretty sure the e99 turbo is the same flow as the obs, just different in the way it bolts on and the exh housing is different because of the wastegate and SD down pipe.
he could use you spyder tho if he gets an intercooler, it will hook right up the OBS turbo and intake plenums
CCLB with some stuff done .....
BigRed97 is offline
post #5 of 12 (permalink) Old 01-26-2010, 01:41 AM
Village Idiot
southmike's Avatar
Def on to something there I know the obs d66 turbo has a diff mount then the sd.
As for the rest I am obs challenged
post #6 of 12 (permalink) Old 01-26-2010, 02:03 AM Thread Starter
I like turtles
NE-STROKE's Avatar
Thanks that answered my question
Now I wonder how much each piece is worth.
small plenums?
spyder?
turbo?
pedastal?
up pipes?
intercooler pipes?
thanks
post #7 of 12 (permalink) Old 01-26-2010, 02:09 AM
<< wasted fuel >>
haulin99sdp's Avatar
another benifit would be he could add a 38r later down the road.
it will bolt right in a late style sd setup.
haulin99sdp is offline
post #8 of 12 (permalink) Old 01-26-2010, 02:43 AM
The Oracle
BigRed97's Avatar
small plenums?
spyder?
turbo?
pedastal?
up pipes?
intercooler pipes?
thanks
i think the spyder and the intercooler pipes are the only things that will get any money
not sure i'd call it a benifit, since he'd have to change everything again??
the up pipes and pedistal, spyder, and plenum are all different on 99.5+ (arent they?)
BigRed97 is offline
post #9 of 12 (permalink) Old 01-26-2010, 02:47 AM Thread Starter
I like turtles
NE-STROKE's Avatar
Yes all that is differnt on a late 99.
post #10 of 12 (permalink) Old 01-30-2010, 08:15 AM
sam's club member
Jet Fuel's Avatar
The 38r is a pain to cram in an OBS, it requires a very big hammer to the fire wall.(I expected to see the radio knocked onto the front seat) It will not fit on a e99 pedestal either. the e99 turbo pedestal is shorter than the late 99, the 38r and late 99 turbo housing will hit the head if you tried it.
I wouldn't bother changing out the turbo, just use the e99 spider and add an I/C, maybe a 1.0 housing if he wants the awesome experience of removing the OBS turbo.
Real men wash their hands before they pee
Jet Fuel is offline
