6.0 IC swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-25-2010, 12:55 AM Thread Starter
fishstick's Avatar
6.0 IC swap
Should I do a 6.0 IC swap will it help egts and flow or just a wast of time?
2000 CC LB 6 speed w shortshift,gt38, 250/100hybrids,pushrods,910,gauges,tuned by beans ,5in,afe2,ccvmod,DI RR,Bobs Hpop
fishstick is offline
post #2 of 6 (permalink) Old 01-25-2010, 01:20 AM
Village Idiot
southmike's Avatar
Re: 6.0 IC swap
If you can get one cheap it may be worth it it may drop the egts down about 50 or so, possibly more towing..they are not as good asw the aftermarket ones but don't cost 1k or more either.
southmike is offline
post #3 of 6 (permalink) Old 01-25-2010, 01:24 AM
P.F.F.
smokindiesel2's Avatar
Re: 6.0 IC swap
I just got done doing this mod, finished yesterday. Haven't gotten much time on it yet but today I brought a load of wood down from the mountains and noticed with a load my EGT's were about 60* to 80* cooler then two weeks ago with the same load. Also seemed to cool down a little faster while waiting to shut the truck down. If you can get the intercooler for a good price I'd say do it till you can upgrade.
02 F-250 4X4
96 F-250 4X4
smokindiesel2 is offline
post #4 of 6 (permalink) Old 01-25-2010, 01:44 AM
jkidd_39's Avatar
Re: 6.0 IC swap
If you can grab one for around $150 then do it.
I saw a 100 degree drop everywhere and boost builds alot faster. I am very happy with mine.
2002 F-350 CCLB 7.3 250,000 Miles *** 5" MKO Power Exhaust, 6637, Foil Delete, DB's HT Starter, EV2 Gauges, 6.0 IC/TC, Van Turbo, WW, Casserly Stg. 1 Singles, BTS VB, DP Tuner, HPX***
2008 F-450 CCDRW 80k ***4"DP-5"MBRP, S&B Intake, Elite EGR delete w/ wastegate, Elite Studs, DPF/DOC delete, KEM 345***
jkidd_39 is offline
post #5 of 6 (permalink) Old 01-25-2010, 02:18 AM
dinnerbooter treasurer
genuineford's Avatar
Re: 6.0 IC swap
If yours is the all aluminum version I would not get rid of it. If you ever want to make some real boost someday you will need an intercooler that doesn't have plastic ends.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #6 of 6 (permalink) Old 01-25-2010, 02:59 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: 6.0 IC swap
i found it worthwhile.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
