Low Torque @ 702 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-24-2010, 04:42 AM Thread Starter
Caution! May Blow Smoke
Bigcat350's Avatar
Low Torque @ 702
What would cause low torque? I guess it could be in the tuning but I would like some opinions. I dyno over 400hp but just hit 702 torque maybe thats OK but seems low to me.
Eddie
Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter,Muffler Delete,Stancore GPR, Swamps Hybrid Single Shot Injectors,DP Tuner,CCV, AIH Delete, Foil Delete, Garrett GTP38R BB Turbo with1.15 Housing,Valair, Over 400HP (SOLD)
(FOR SALE)=(SOLD)
Bigcat350 is offline
post #2 of 13 (permalink) Old 01-24-2010, 05:11 AM
Snake Oil Salesman
mattr66's Avatar
Re: Low Torque @ 702
where was your peak torque RPM? What kind of dyno was it? Eddy current motors installed?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #3 of 13 (permalink) Old 01-24-2010, 05:18 AM Thread Starter
Bigcat350's Avatar
2900-3000 RPM and a Dynojet.
Eddie
(FOR SALE)=(SOLD)
post #4 of 13 (permalink) Old 01-24-2010, 05:28 AM
you want some of this?
smorris's Avatar
Numbers right on the mark.
tq x rpm / 5252 =hp
(702 x 3000)= 2,106,000
2,106,000 / 5252= 400.99009 hp
Dead nuts.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #5 of 13 (permalink) Old 01-24-2010, 06:19 AM
TRX370r's Avatar
Mine did 404 hp and 727 ft lbs on a Dyno jet. Id say your numbers are good.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #6 of 13 (permalink) Old 01-24-2010, 06:46 AM
Death Row Inmate #7
strokin'_tatsch's Avatar
dang, mine did 352hp and 731tq w/ stage 1 injectors, but i don't remember what ART's dyno was. seemed pretty in line from what some guys ran in bowling green. maybe my truck is just an odd ball..
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
post #7 of 13 (permalink) Old 01-24-2010, 11:42 AM
TARM's Avatar
In your sig you have Hybrids and a 38R. What size Hybrids are they? CC and nozzle No doubt your numbers are dead per the formula which I would expect unless something was wrong with the dyno. Also do you have the graph print of the dyno run showing the curves?
TARM is offline
post #8 of 13 (permalink) Old 01-24-2010, 06:05 PM
Snake Oil Salesman
mattr66's Avatar
It is sometimes hard to load a turbodiesel on a dyno without eddy current motors to help put a load on the truck. Did they run it in direct and where did they go WOT RPM-wise? That seems like a really high torque peak. Horsepower peaking there would be more logical.
Matt Robinson
mattr66 is offline
post #9 of 13 (permalink) Old 01-24-2010, 07:10 PM Thread Starter
Bigcat350's Avatar
I have the 200/30% hybrids. Yes here is the dyno print out. Matt I am not sure where they loaded it while I was on it maybe the chart will help. I just thought it was a little low but as said right on using the formula. I was not running tunes for this set up I still had the tunes for the 174/146 SS that I had in with stock turbo that's what I had when I got the F5. The first run was in 80e the other 2 was 140 tune. My icp is good also I have 2800-2900 in 140 @ WOT
Eddie
(FOR SALE)=(SOLD)
post #10 of 13 (permalink) Old 01-24-2010, 08:27 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
the power really held on good up top.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
