New Built Trans have ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 01-23-2010, 04:20 AM Thread Starter
99psd-white's Avatar
I recently got my trans rebuild by a well known local shop here in SW Michigan. Billet converter, valve body, clutches, pretty much all the works! My question is I have a DP tuner and wondering if its necessary to have it sent back to Jody for a reburn for the new line pressures of the new tranny and billet converter and what not?
Also another question.. my truck is an early 99 and i was watching this video on youtube that is posted below and at the end of the video the truck like laughs after the dyno run. What is it doing exactly? is it bad? because my truck does that to when i rev it up in my 80 econ stage?
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
18" muzzi hulk wheel
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
BDS steering stabilizer with duel Bilstein shocks
UWS tool box
Hide-a-way gooseneck hitch
Built trans
CCV mod
Zoodad mod
Amp steps
99psd-white is offline
post #2 of 20 (permalink) Old 01-23-2010, 05:50 AM
<< wasted fuel >>
haulin99sdp's Avatar
Re: New Built Trans have ?
a good reburn would be apporiate to take advantage of your new tranny and to smooth out all the shift points, tc lockup, line presure, ect.
give dp tuner a call and im shure they will fix you right up. i would not beat on it until new tunes are in.
haulin99sdp is offline
post #3 of 20 (permalink) Old 01-23-2010, 07:50 AM
TARM's Avatar
http://www.youtube.com/watch?v=qgm1Bl0XfbI
ICP coming back down after WOT run maybe?
TARM is offline
post #4 of 20 (permalink) Old 01-23-2010, 07:51 AM
TARM's Avatar
ICP still high from WOT run and then coming back down after the fact maybe?
TARM is offline
post #5 of 20 (permalink) Old 01-23-2010, 02:51 PM
Village Idiot
southmike's Avatar
possibly fuel cackle, have you changed the fuel system.
there are a couple of fittings that can let air in.
my truck will sound like that bone stock if you let up while on the highway etc...but only when i let off...never reving up.
southmike is offline
post #6 of 20 (permalink) Old 01-23-2010, 02:55 PM
i see banks power under the f-350 emblem....... could that be the problem?
countryboyrob is offline
post #7 of 20 (permalink) Old 01-23-2010, 06:41 PM
Tampa450's Avatar
None of the 7.3's Ive owned made a noise like that...ever.
That doesnt sound like "fuel cackle" to me......or at least what I thought was cackle.
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
post #8 of 20 (permalink) Old 01-23-2010, 06:47 PM
Butt-Head
PHPDiesel's Avatar
ICP stabilizing. Seems to me that an IPR replacement should be on the list of things-to-do.
Or, depending on whether or not the truck has aftermarket tuning (like yours does), the IPR duty cycle map needs to be altered to give a better response time from 80% (arbitrary aftermarket tuning number) to 5%.
Cody
PHPDiesel is offline
post #9 of 20 (permalink) Old 01-23-2010, 06:49 PM
If I read the OP right he had found that video on youtube so thats not his truck?
post #10 of 20 (permalink) Old 01-23-2010, 07:06 PM
Butt-Head
PHPDiesel's Avatar
Right, but he said that his truck does the same thing.
Cody
