gen III style hpop. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 01-22-2010, 04:17 AM Thread Starter
<< wasted fuel >>
haulin99sdp's Avatar
gen III style hpop.
how many guys running a gen III or simalier hpo setup, and what type of driving do you do with it?(hiway miles, dd, tow, or other)
how much more does it deplete the oil that you guys have seen, and also what type of gains were noticed. thanks in advance.
haulin99sdp is offline
post #2 of 37 (permalink) Old 01-22-2010, 09:00 PM Thread Starter
<< wasted fuel >>
Re: gen III style hpop.
i am about to have one in my hands and was just wondering from people that have acctually run this style setup.
post #3 of 37 (permalink) Old 01-26-2010, 03:05 AM Thread Starter
<< wasted fuel >>
any dd's with this stlye setup? any and all info is greatly appreciated!
post #4 of 37 (permalink) Old 01-26-2010, 05:55 AM
2Cruel
moremph's Avatar
I drove the first gen3 on my daily driver in testing for 15k or so, No problems whatsoever, good oil pressure and still changed the oil every 5k withgood results, Swamp has one on his daily driver now i am sure he could answer any question you may have about daily driving a gen3. Its been a long time since i have had a souped up daily driver lol
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #5 of 37 (permalink) Old 01-26-2010, 02:58 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
I have a gen3 on my truck... Although it's not 'daily' driven it is a 'dd street truck' and there's really no adverse affects to it aside from the 5-25 second shake on startup Jon said that's just the nature of the beast
Stock
PowerstrokeJunkie is offline
post #6 of 37 (permalink) Old 01-26-2010, 03:02 PM Thread Starter
<< wasted fuel >>
if you dont mind tellin, what size injectors you pumpin that much oil to?
post #7 of 37 (permalink) Old 01-26-2010, 03:19 PM
Junior Mint
The only problem I have w/ it is I am not able to find a Viton shaft seal for the pump and I lost a shaft seal after approximately 10K miles.
I wonder if Swamps has tracked some down and is providing them?
Also, I don't get any weird shaking at start up.
As far as oil volume goes, it's more than enough for anything you got.
I'm officially...Stroke-less.
Suns_PSD is offline
post #8 of 37 (permalink) Old 01-26-2010, 05:18 PM
Hybrids
Stock
post #9 of 37 (permalink) Old 01-26-2010, 06:05 PM Thread Starter
<< wasted fuel >>
does anyone know where the viton shaft seals could be aquired if ever needed?
post #10 of 37 (permalink) Old 01-26-2010, 06:35 PM
HRT Performance
HotRodTractor's Avatar
Do you guys have any specs on the seal? Cross referencing the seal shouldn't be that hard if you have the shaft OD, bore ID, and pocket depth to start out. You know you want it made of viton. Those items alone should get you close. Is this seal a high pressure seal, or is it a low pressure seal? Take that information to a sealing and packing place and you will find what you are looking for.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
