Filling Block After machine work??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-19-2010, 11:45 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
I recently bought a fully built engine with the exception of it being filled. Has a full girdle to the pan rails and all the other good stuff inside. Now the last thing I want is to split the block and Im wondering if it would be a good idea to fill it to help with flex.
Im looking for 7-800 on fuel with my set of compounds and some 400/600's.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 11 (permalink) Old 01-19-2010, 11:57 PM
fueled by Colecovision
golfer's Avatar
Garage
Re: Filling Block After machine work???
ooooffph...
definitely not the order to do it....
I would say take all of your pre-assembly measurements with your dial bore gauge...cylinder bore diameters top bottom, L to R & F to B...see if the cyls are egged at all...
then torque a cylinder head to the block and remeasure w/ dial bore gauge.
if the cylinders get "rounder" (and/or less tapered) with the head tq'd on the block..then you might be able to get by with a hone after filling and it curing WITH a head or deckplate bolted to it...
if the machine shop didn't bore & hone with a deckplate...then the cylinders will probably get 'worse' (out of round & tapered) WITH a head on it...which means that you'll have to bore & hone to straighten them out...but you probably already have pistons..........
check your measurements with & w/o a head (or deckplate) bolted on...and if the cyls move a lot (>.001)...then I would fill it
good luck.
Dave
golfer is offline
post #3 of 11 (permalink) Old 01-20-2010, 12:22 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Thanks, the engine is all assembled and ready to go. I realy dont want to take it all appart, but then again I dont want to split it either. It has been line honed with the girdle on it already, so I assume this may be a problem as well. Also this is still the stock bore.
On the other hand if stock internal engines can go 6-700, I would think 7-800 would be ok with a full girdle etc.
Tow Mule
post #4 of 11 (permalink) Old 01-20-2010, 02:02 AM
Plays with Motors
Machinist's Avatar
It won't be a problem to add the concrete now if you pulled the heads and leveled it out, not the ideal situation, but only on the most finicky thin wall SBC blocks have I seen it be a problem.
The mix is designed to expand at the same rate as the cast iron, it does to a certain extent but whether you fill before or after machine work the concrete still causes distortions that wouldn't be there if the block was not filled. They get worse as the block gets up to temp, but that's the trade-off for having a more stable bore - the hope is that the gains from eliminating cylinder wall flex and "maybe" helping the bottom end some outweighs the bad.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #5 of 11 (permalink) Old 01-20-2010, 02:23 AM
golfer's Avatar
Garage
If Machinist says it's all good...then it's allll goood.
I'd fill it..let the chit cure with a head bolted to it, and roll on...
I just don't see how you're going to get away with cleaning it as well as it should if it is allll assembled.
I'd get a coolant filter kit, and a fewwwww extra filters...and swap those bishes out every couple hundred miles and take a peek to see when it quits catching flakes. Probably save you an oil cooler down the road.
take care~
Dave
golfer is offline
post #6 of 11 (permalink) Old 01-20-2010, 02:30 AM
Banning Smut
PTSUPERD's Avatar
Coolant filter is a GREAT idea.
Dieselsite has a nice clean simple external filter. Real easy to mount on the frame rail.
PTSUPERD is offline
post #7 of 11 (permalink) Old 01-20-2010, 02:58 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
With that said would it be worth while to do, or should everything be ok? There is no dispute it stiffens the walls, but is it needed in my case?
Tow Mule
post #8 of 11 (permalink) Old 01-20-2010, 03:23 AM
Pipewhiner's Avatar
HMMM full girdle to the pan rails..... I only know of one other motor or so that has that girdle....
1999.5 Brugundy/Black CC 4x4 Dually BTS, IH DTA360 conversion completed
Pipewhiner is offline
post #9 of 11 (permalink) Old 01-20-2010, 03:29 AM Thread Starter
Got Bost???
NyCowboy87's Avatar
Well gotta add another to the list
Tow Mule
post #10 of 11 (permalink) Old 01-20-2010, 04:39 AM
Pulling sled for hire
ParkerFly's Avatar
Different girdle from that engine, IIRC.
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
