water/meth with new build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 01-17-2010, 10:00 PM Thread Starter
silverpsd_06's Avatar
I'm putting together a different setup for my truck 275/226 swamps hybrids with a s465 turbo home built mount, diy fuel system, at min a adrenaline hpop, springs studs and pushrods.... I'm also looking at a coolingmist water meth injection is there such a thing as too much meth or is it all controlled by your boost levels? How do they work and how much is too much? Any help or ideas/tips are appreciated thanks
2000 f-350 SRW CC, 6" lift 22" KMC wrapped in 37" Toyo's, S465, Swamps 275/226, Studs, Springs, Pushrods, Gen3, TS 6 pos chip with Swamps Tunes...
silverpsd_06 is offline
post #2 of 19 (permalink) Old 01-17-2010, 10:09 PM
<< wasted fuel >>
haulin99sdp's Avatar
Re: water/meth with new build
if you run meth, keep the meth % down as much as possiable but then again it also depends what you are going for.
i have heard a lot of people say to run just h2o.
haulin99sdp is offline
post #3 of 19 (permalink) Old 01-17-2010, 10:53 PM Thread Starter
Does anyone know what a safe percentage is for a mild performance gain say maybe 65-75 horsepower gain at max or is that feasible with what I'm wanting to do which is for the most part help keep egts down
post #4 of 19 (permalink) Old 01-17-2010, 11:20 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
40% is all I would run... I have tested up to 70% with stock injectors, not worth the damage...
Joe
CSIPSD is offline
post #5 of 19 (permalink) Old 01-17-2010, 11:31 PM
PSN Pretender
907DAVE's Avatar
Does the volume(jet size) of meth/water you are injecting effect how you mix?
907DAVE is offline
post #6 of 19 (permalink) Old 01-17-2010, 11:56 PM Thread Starter
What gains did u get with 40% and I'm after more of a safer side of things and keeping egts down but 40% would be max I would run
post #7 of 19 (permalink) Old 01-18-2010, 02:59 AM
TARM's Avatar
I would stick to water only set to boost for perf. If you do run meth that I would strongly recommend live tuning.
TARM is offline
post #8 of 19 (permalink) Old 01-18-2010, 04:38 AM
tbolt's Avatar
Ever seen what happens when the sys screws up? Hydrolock is fatal. Happened to a guy I know.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #9 of 19 (permalink) Old 01-18-2010, 05:14 AM
TARM's Avatar
That is why it pays not to go cheap. Pay the extra for the failsafes etc..
TARM is offline
post #10 of 19 (permalink) Old 01-18-2010, 06:03 AM
PSN Pretender
907DAVE's Avatar
What are the extra failsafes?
907DAVE is offline
