Fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 01-17-2010, 09:44 AM Thread Starter
Fuel
so i got a ? i was thinking bout doing a fuel filter delete and a regulated return and then take the stock electric fuel pump out of the system and putting a 150GPH air dog in its place and then adding a 2 micron filter after the airdog would this provide sufficient fuel to the injectors
fordpower2008 is offline
post #2 of 10 (permalink) Old 01-17-2010, 09:46 AM
<< wasted fuel >>
haulin99sdp's Avatar
Re: Fuel
depends on what injectors and your gonna want a post pump filter also(fuel/water seperator).
it should be plenty with the r&r.
haulin99sdp is offline
post #3 of 10 (permalink) Old 01-17-2010, 09:47 AM
PSN Pretender
907DAVE's Avatar
Re: Fuel
Not sure about the new airdog but, they were not intended as a stand alone pump, but more like a lift pump to supply another high pressure pump. But other will correct me if I am wrong.
907DAVE is offline
post #4 of 10 (permalink) Old 01-17-2010, 09:52 AM
<< wasted fuel >>
Re: Fuel
the walbro can be had for a lot cheaper and does just as good.
post #5 of 10 (permalink) Old 01-17-2010, 01:08 PM
Back to Civilian Life!!
MILFORD's Avatar
Re: Fuel
I would go with an airdog and a walbro.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #6 of 10 (permalink) Old 01-17-2010, 08:54 PM
PSN Pretender
907DAVE's Avatar
Re: Fuel
My walbro lasted 8 months fueling 238's. And went through 2 factory pumps before that. So after all the money spent on pumps that "should be fine", I could have built a complete fuel system. My vote goes for the Fuel Lab pump, and build the rest of your system. Do a search for DIY fuel systems, lots of great info!
907DAVE is offline
post #7 of 10 (permalink) Old 01-17-2010, 09:03 PM
dinnerbooter treasurer
genuineford's Avatar
Re: Fuel
TSD sump and fuel system installation - Powerstroke Nation
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #8 of 10 (permalink) Old 01-17-2010, 10:24 PM
Getting Faster...
Izzy351's Avatar
Re: Fuel
Not to hijack, but I'm going through this right now. Got my RR in -- holding about 75-80 psi at idle, but something is making a hell of a noise under the truck. When yours went out, did it start making noises or just fail? Here's what mine's sounding like right now:
Izzy351 is offline
post #9 of 10 (permalink) Old 01-17-2010, 10:35 PM
PSN Pretender
907DAVE's Avatar
Re: Fuel
WOW..........that pretty crazy. No mine did not sound anything like that, the factory ones got louder until they just quit, and the walbro never changed pitch but would not maintain pressure under load.
And 75-80 at idle is to high, should be around 65psi.
907DAVE is offline
post #10 of 10 (permalink) Old 01-17-2010, 10:38 PM
Getting Faster...
Izzy351's Avatar
Re: Fuel
Yeah, I need to adjust the regulator. I was at 65 before the RR, and never touched the FPR.
Izzy351 is offline
