Trans dipstick - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 01-17-2010, 06:58 AM Thread Starter
cemeyer's Avatar
Trans dipstick
Does anyone have a transmission dipstick tube and dipstick that they could measure how much the dipstick sticks out of the tube? I cut mine apart to make a new one and I lost my measurement. The stock one did not fit to my liking with the h2e setup and feeding fuel from the rear of the heads. Thanks to anyone who takes the time to find this out for me.
Curt
97 350 CC LB 4x4
Injectors, oil, H2E, studs, 910's, idm, etc...
cemeyer is offline
post #2 of 8 (permalink) Old 01-17-2010, 08:24 AM
TARM's Avatar
Re: Trans dipstick
If you are sure that you tranny has the correct amount of oil then you can simply use that a make your marks. Sorry if I had one out I would be glad to measure it for you.
TARM is offline
post #3 of 8 (permalink) Old 01-17-2010, 07:25 PM Thread Starter
cemeyer's Avatar
Re: Trans dipstick
No, I not sure if it has the right amount in it. I thought about it, but I'd rather get an actual measurement.
Curt
97 350 CC LB 4x4
cemeyer is offline
post #4 of 8 (permalink) Old 01-17-2010, 10:55 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: Trans dipstick
i can get it for you tomm. if no one else knows.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #5 of 8 (permalink) Old 01-18-2010, 02:41 AM Thread Starter
cemeyer's Avatar
Re: Trans dipstick
Thank you. I found another tube today. 8 5/8 is what I came up with. Hopefully it is right.
Curt
97 350 CC LB 4x4
cemeyer is offline
post #6 of 8 (permalink) Old 01-18-2010, 03:30 AM
Crazy Talk
Re: Trans dipstick
sounds about right. i had the same prob so i got rid of the tube and shortened the dipstick. now i crawl under it and stick it in the short tube thats stuck in the trans.
post #7 of 8 (permalink) Old 01-18-2010, 03:44 AM Thread Starter
cemeyer's Avatar
Re: Trans dipstick
I used a piesce of 1/2 emt and made it come up beside the oil dipstick.
Curt
97 350 CC LB 4x4
cemeyer is offline
post #8 of 8 (permalink) Old 01-18-2010, 03:45 AM
TARM's Avatar
Re: Trans dipstick
You should take your truck to a Jiffy Lube and ask them to check the tranny fluid. See how long it takes before they give up and come and ask you if you know where the dip stick is located. Better yet video the guy.
TARM is offline
