spooling...what causes it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 01-17-2010, 12:42 AM Thread Starter
wheres the fat chicks?
PowerstrokeR00's Avatar
exactly what the title asks....what causes spooling
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #2 of 8 (permalink) Old 01-17-2010, 12:43 AM
Re: spooling...what causes it?
when you put a load on the engine in order to get the turbo "lit" so that there is almost no turbo lag.
02 f250
countryboyrob is offline
post #3 of 8 (permalink) Old 01-17-2010, 12:50 AM Thread Starter
is the spooling worse when you increase the size of ur downpipe
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #4 of 8 (permalink) Old 01-17-2010, 12:56 AM
are you asking if spoling is bad?
post #5 of 8 (permalink) Old 01-17-2010, 01:03 AM
Roamer
Evil Diesel's Avatar
yah spooling is bad when u dont want to make power
Evil Diesel is offline
post #6 of 8 (permalink) Old 01-17-2010, 01:22 AM
POWERSTROKEMIKE
others will chime in .. but spooling is the amount of time it takes to build boost.. like lets say your sitting at the lite an it turns green you floor it.. well the truck goes but your not really building boost maybe a few seconds till it builds some boost an the truck really moves..
the down pipe (outlet) from the trubo doesnt really matter.. its more the size of the turbo..
powerstrokemike is offline
post #7 of 8 (permalink) Old 01-17-2010, 03:02 AM Thread Starter
i know its not bad.just wandering wat causes it
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #8 of 8 (permalink) Old 01-17-2010, 03:17 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
the pressure of the exhaust (back pressure) spinning the turbine wheel of the turbo spinning the shaft to the compressor wheel that forces fresh air into the engine and causes the wistle. thats it in a nutshell. theres more to it but thats the basics. post turbo doesnt really matter but a bigger dp just makes it flow better
Refugee
pstroke96 is offline
