HEad studs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 01-14-2010, 04:23 PM Thread Starter
Jomax's Avatar
HEad studs
How much is it for a 7.3 diesel to get head studs from a shop. And if i do decide to tackle it myself how hard is it??
Jomax is offline
post #2 of 29 (permalink) Old 01-14-2010, 04:47 PM
Deputydog's Avatar
Re: HEad studs
It is labor intesive. I guess it depends on the shop rate, but I would expect to pay for 10+ hours of labor plus the studs.
You can tackle it yourself if you have the tools and a place to do it.. There are several guys that have done some nice write-ups about it..
Deputydog is offline
post #3 of 29 (permalink) Old 01-14-2010, 05:24 PM Thread Starter
Jomax's Avatar
Re: HEad studs
It would be cheaper to do then a 6.0 right?
Jomax is offline
post #4 of 29 (permalink) Old 01-14-2010, 05:40 PM
BDP Tuner's Avatar
Re: HEad studs
Yes it would be cheaper than a 6.0. If you brought the truck to BDP the labor to install studs would be around $1500 we pull the motor when we install studs on a 7.3. If we can help just let us know.
BDP Tuner is offline
post #5 of 29 (permalink) Old 01-14-2010, 05:41 PM Thread Starter
Jomax's Avatar
Re: HEad studs
Thanks ill try to put the money together and get it done sometime this year.
Jomax is offline
post #6 of 29 (permalink) Old 01-14-2010, 06:49 PM
The Fireman
big_stroker's Avatar
Re: HEad studs
Nate at Unlimited Diesel charges $650 for labor + the cost of the studs.
I think you could do it your self with the motor in the truck.
big_stroker is offline
post #7 of 29 (permalink) Old 01-14-2010, 07:26 PM
TARM's Avatar
Re: HEad studs
Yhe only sticky part is the rear ones on each side. You need to loosen the motor mounts to torque the engine to get it in. Why your in the you really should do the springs and P-rods.
TARM is offline
post #8 of 29 (permalink) Old 01-14-2010, 08:44 PM Thread Starter
Jomax's Avatar
Re: HEad studs
P rods???
Jomax is offline
post #9 of 29 (permalink) Old 01-14-2010, 08:56 PM
screw the DARK SIDE
97strokn&smokn's Avatar
Re: HEad studs
P rods???
Push rods
2007 f350
1997 F350.
97strokn&smokn is offline
post #10 of 29 (permalink) Old 01-14-2010, 09:03 PM
<< wasted fuel >>
haulin99sdp's Avatar
Re: HEad studs
910 springs, pushrods, studs and be done. do you plan on any further mods to the truck?(injectors, turbo, etc.)
haulin99sdp is offline
