Freeze Plug - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 01-13-2010, 05:55 PM Thread Starter
Busy Busy
Marty's Avatar
Freeze Plug
What is their actual purpose in the block? Dom, Aaron and I were talking about how many cummins have blown them.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 27 (permalink) Old 01-13-2010, 05:57 PM
bluedge8's Avatar
Re: Freeze Plug
their actual purpose is to remove the sand from the casting proccess when making the block.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #3 of 27 (permalink) Old 01-13-2010, 06:05 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Freeze Plug
That's what I thought?
So is there a reason they can't be threaded and plugged?
Might have saved Snow White
Elkton, Maryland
Marty is offline
post #4 of 27 (permalink) Old 01-13-2010, 06:18 PM
Re: Freeze Plug
they are to relieve pressure in the event of your coolant freezing so that it does not crack the block. As long as your coolant is mixed properly you shouldnt have any problems
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #5 of 27 (permalink) Old 01-13-2010, 06:46 PM
aggie's Avatar
Re: Freeze Plug
What luke said.
cummins pop the rear freeze plug because they have poor coolant circulation and develop hot spots(esp since the rear cyls run hotter on a common rail) and thus develop pressure and pop. Some also think the water pumps pump too much at higher rpms and develop pressure as well.
Freeze plugs can be pinned or tapped or various diffrent things.
on edit, i doubt those woule have saved snow white, if i remember correctly the block cracked, freeze plugs flying out were a side effect.
[SIGPIC][/SIGPIC]
aggie is offline
post #6 of 27 (permalink) Old 01-13-2010, 06:51 PM
HRT Performance
HotRodTractor's Avatar
Re: Freeze Plug
Originally Posted by aggie View Post
What luke said.
There are several people that have installed threaded plugs and pinned plugs on Cummins engines. There are freeze plugs under the valve covers that IMHO should be tapped and plugged. Many run a plate that covers the back plug and hold it in place. One issue is the belt driven water pumps with higher RPMs. they generate too much pressure in the block and cause some of these issues. That is why many people have "clipped" water pumps or electric water pumps.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 27 (permalink) Old 01-13-2010, 07:47 PM
bluedge8's Avatar
Re: Freeze Plug
I was always told this is a side effect, and freeze plugs DO NOT always save a block from freezing- I have seen or heard of more than a few blocks that were cracked anyway.
bluedge8 is offline
post #8 of 27 (permalink) Old 01-13-2010, 07:48 PM
bluedge8's Avatar
Re: Freeze Plug
another reason a high hp motor may blow a plug is due to the block flexing and the plug being pressed in, some of the above methods may help to not have a problem on the track assuming the motor is in one piece on the big end.
bluedge8 is offline
post #9 of 27 (permalink) Old 01-13-2010, 09:37 PM
All done now
Arisley's Avatar
Re: Freeze Plug
I have always been told the same thing, they are casting plugs to empty the sand after making the block. They may or may not save the block from breaking if it freezes.
Arisley is offline
post #10 of 27 (permalink) Old 01-13-2010, 09:40 PM
OBS junkie
Cat_Rebel's Avatar
Re: Freeze Plug
So what are we thinking Marty, big pipe plugs?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
