IDM relocation? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-13-2010, 04:06 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
IDM relocation?
Anyone ever do this? I swear if I ever meet the engineer that stuffed it up under the fender well I am going to slap him.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 6 (permalink) Old 01-13-2010, 04:13 PM
HRT Performance
HotRodTractor's Avatar
Re: IDM relocation?
I relocated it to a '79 body!
Seriously though - I do agree that it is in a stupid place. I don't think there is enough wire there to move it anywhere else without either cutting and splicing in wires to extend the harness or build a jumper harness to extend the connection point. For some reason I am pretty sure Charles found the correct connectors for both the male and female sides of that plug that would make building a harness possible. In fact I have been meaning to get a hold of him to see if he still has the PNs so I can start work on the new harness for the '79.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #3 of 6 (permalink) Old 01-13-2010, 04:56 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
Re: IDM relocation?
I was thinking of the jumper idea and a harness from a wrecking yard would give you the wire and one connector, however it looks like if you pulled the harness back through the fender and maybe moved a couple things a bit it could be mounted in a vertical position. I'm going to look at this some more today. I've had to R&R mine twice now and the fender lip and fender well flap are starting to suffer a it.
Big Bore is offline
post #4 of 6 (permalink) Old 01-13-2010, 10:20 PM
jeromejcp's Avatar
Re: IDM relocation?
Has anyone tried to weatherproof the idm any better instead of relocating it? Seems like this is becoming a common problem. I am going to look this weekend when I replace mine.
Cheers
JP5
00 F350 CC LB 4x4 auto. Nitto Terra 285 75 r16 E, Dynatrac free spin hubs, ccv, rancho stabilizer, centramatics, upgraded GPR, DB starter, 2.0 ga pos cable, matching 5th rim, 6637, 4" SS magnaflow, CPR, Scan Gauge, Mag Hytech.
USN VBSS, Burn sink or take a-prize.
jeromejcp is offline
post #5 of 6 (permalink) Old 01-13-2010, 10:59 PM
All done now
Arisley's Avatar
Re: IDM relocation?
I wonder if there is enough room to mount it inside the cab somewhere like the PCM is.
Arisley is offline
post #6 of 6 (permalink) Old 01-14-2010, 03:09 AM
Well Hung Member
stroked's Avatar
Re: IDM relocation?
why? you have to take yours out that often? didnt take me very long to drop my inner fender and take care of business,
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
