Turbo question s476-88 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 51 (permalink) Old 01-12-2010, 11:32 PM Thread Starter
Back in Black
stroken's Avatar
Hey guys, I have 300/200 injectors with a k31 right now. other mods are in sig. I am thinking of doing a s476. i wanted to do an s480 but everyone told me it was too large to use on a dd truck, cant stay ontop the turbo.
What is yalls opinions of a s 476 with an 88mm inducer on the exhaust side with my injectors and setup?
Thanks for the imput
Kenny
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
post #2 of 51 (permalink) Old 01-12-2010, 11:40 PM
<---- my shop
vader's fury's Avatar
Re: Turbo question s476-88
from what i understand i believe you would be good with that turbo. I have 238/100% and plan to run a 476/82. but i am no expert
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #3 of 51 (permalink) Old 01-13-2010, 12:01 AM
What else?
smokyred's Avatar
I think it would work pretty decent. I'm running a 476/88 (BFH) with IIRC a 1.30 T4 housing and smaller injectors than what you have for the winter. Mine was built so I can run 300/400's this coming year.
I'd give Swamps a call and see what they think, I got mine from them.
Dave
smokyred is offline
post #4 of 51 (permalink) Old 01-13-2010, 12:05 AM Thread Starter
Back in Black
stroken's Avatar
my engine is fully built also.
I plan on running this but want to go to a 400% nozzle later. and hope that wont be "too much" for the turbo then.
I think even with 400% nozzles an 480 will be hard to keep spooled and not fun to drive on the street.
stroken is offline
post #5 of 51 (permalink) Old 01-13-2010, 12:36 AM
Crazy Redneck
UNCOOL's Avatar
Kenny,
I would have to think the 88mm is the EXDUCER of the turbine wheel. The inducer is most likely in the 96mm range.
FWIW, I run an S476/88mm exducer on my truck with just a set of stg 1's for now, and I LOVE the turbo. It lites fast, it will bark on the shifts, but I have no problems keeping it lit even with the stg 1's. Towing is awsome with this charger. (.90 exhaust housing, so I have room to grow if BP becomes an issue)
I think you will be much happier with it than what you were originally looking to run from your other posts.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #6 of 51 (permalink) Old 01-13-2010, 12:38 AM Thread Starter
Back in Black
stroken's Avatar
Thanks for the imput uncool - BTW what is a stage 1 considered?
SO if you can keep it spooled and all with stage 1 (if they are what i am thinking) wont it be too small for a 300/200 or 300/400?
stroken is offline
post #7 of 51 (permalink) Old 01-13-2010, 12:46 AM
Crazy Redneck
UNCOOL's Avatar
Stg 1 as in 160ish cc stockish nozzled injectors. They are a set of Hypermax stg1's that are about 7 years old. I really have no idea how much they flow.
This turbo has been run with a set of 400+ cc B codes with a few mods. I think you'll be just fine.
Marc
533/1050 5-8-10
#32
UNCOOL is offline
post #8 of 51 (permalink) Old 01-13-2010, 12:48 AM Thread Starter
Back in Black
stroken's Avatar
wow. its shocking to me those injectors spool that turbo. I ran stock injectors with my k31 for 2 weeks. how not fun that was!
what size exh housing you reccomend?
THanks for the help!!
stroken is offline
post #9 of 51 (permalink) Old 01-13-2010, 12:49 AM
What else?
smokyred's Avatar
It's too late to edit my post, but my turbine housing is a 1.32. I'm currently running this turbo with a set of 170ish A codes, stock nozzles.
UNCOOL I bet that thing is fun with the .90, I had that housing on my S465 with the 74mm wheel, and it was a blast with stock A codes even.
Dave
smokyred is offline
post #10 of 51 (permalink) Old 01-13-2010, 12:54 AM Thread Starter
Back in Black
stroken's Avatar
so do yall think i should do an 76/88 with 1.0 exh housing or a 80/88 1.0 exh housing. 300/200s now but plan to do 400% in the near future.
I DRIVE THIS EVERYDAY!
stroken is offline
