D66 vs ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 01-12-2010, 10:47 PM Thread Starter
Big Sun fanatic
Ithumpwheniwalk's Avatar
D66 vs ?
Hey all, just looking into a new turbo for my e99, and was wondering the difference between something like this:
http://cgi.ebay.com/ebaymotors/EARLY...%3D5%26ps%3D63
and this?
http://beansdieselperformance.com/st...&productId=100
My truck is never gonna make big HP numbers, I'm not really interested in that, but I plan on mild injector upgrades, Adrenaline HPOP and a chip when i get the injectors. Any thoughts on the two turbos?
(edit: the truck carries a 1700lb camper and say a 1000lb trailer, about max load for me)
Ithumpwheniwalk is offline
post #2 of 14 (permalink) Old 01-13-2010, 02:22 AM
Mtack's Avatar
Re: D66 vs ?
I am sure somebody with more knowledge with me will chime in but I am pretty sure the wicked wheel is the factory wheel for the early 99 so no upgrade there. The biggest thing to me would be Beans reputation vs somebody on ebay. I am no turbo expert so I can`t answer all your questions but here is a link about the wicked wheel from another respected site sponsor.
http://www.dieselsite.com/index.asp?...PROD&ProdID=47
I am in the same boat with the early 99. I am considering the D66 but leaning towards the H2E. I just don`t think I would be comfortable ordering a turbo from another country. Looking at your future plans I`d go with the dominator 66 from beans.
Matt
E99 F350 ECSB SRW 4x4 ZF6 3.73 Adrenaline HPOP, chip, tymar
Mtack is offline
post #3 of 14 (permalink) Old 01-13-2010, 02:58 AM
JHill's Avatar
Re: D66 vs ?
FWIW - do yourself a favor and call Beans and pass on the Ebay turbo.
IIRC the D66 flows enough air to support 500hp. flows a tad more more air than the H2E, although drive pressures are likley lower with the H2E.
What injectors are you planning? if you swap to single shots 160's/180's you could put your $ towards new tunes / newer pcm and not need the hpop.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 14 (permalink) Old 01-13-2010, 03:03 AM
TARM's Avatar
Re: D66 vs ?
All I can say is I know what you will be getting from Beans and you will know exactly what to expect and what its capable of. Beans can tell you exactly what combos will work best with it. I suspect the D66 is the better of the two but as above I am nto turbo expert. But I bet ya Beans and other like Matt,Marty, Jim, etc.. will all know the real differences. I also have to be honest when I see them touting a Banks wicker wheel it makes me suspect. Maybe unwarranted but I still can't help it. You know what you will be getting from Bean's and that they will be there to help you with it anyway you need. That alone has a great amount of value. I do look forward to see the experts analysis on this comparison.
TARM is offline
post #5 of 14 (permalink) Old 01-13-2010, 03:09 AM
Busy Busy
Marty's Avatar
Re: D66 vs ?
Someone has actually made 500 RWHP with a D66??
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 14 (permalink) Old 01-13-2010, 03:11 AM
Was PSD0389
Matt_P's Avatar
Re: D66 vs ?
Yes. 3starJR I think is his name on here
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
post #7 of 14 (permalink) Old 01-13-2010, 03:21 AM
Busy Busy
Marty's Avatar
Re: D66 vs ?
How about another?
Elkton, Maryland
Marty is offline
post #8 of 14 (permalink) Old 01-13-2010, 03:23 AM
Was PSD0389
Matt_P's Avatar
Re: D66 vs ?
How about another?
ummm, well not me. mine broke too much to get it on a dyno and it wasnt near 500 anyways
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #9 of 14 (permalink) Old 01-13-2010, 03:36 AM
Pulling sled for hire
ParkerFly's Avatar
Re: D66 vs ?
How about another?
D66 flows as much as a 38R, so it's possible. Not many people running big enough squirters with a D66 to do it though.
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #10 of 14 (permalink) Old 01-13-2010, 03:44 AM
TARM's Avatar
Re: D66 vs ?
Does it technically have a better boost to drive pressure ratio as well compared to the 38R? I knwo its not BB but I thought I saw it compared to the unmodded H2E for that. If that the case wouldn't 238-250/100s maybe a little head porting and HPOP along with the normal support get you right up there?
TARM is offline
