Will a stock turbo handle Swamps' 175/146 injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 01-12-2010, 10:22 PM Thread Starter
I believe these are Swamps' mildly modded injectors. I am wondering if the stock turbo charger is ok with these?
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #2 of 22 (permalink) Old 01-12-2010, 10:24 PM
TRX370r's Avatar
Re: Will a stock turbo handle swamps 175/146 injectors?
Buy yourself a 1.0 exhaust housing and keep on going with that stock charger. Thats the set-up I'm going to be using soon.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #3 of 22 (permalink) Old 01-12-2010, 11:40 PM
jaybuller's Avatar
Re: Will a stock turbo handle Swamps' 175/146 injectors?
mine worked fine, my injectors were the 175/146 single shots in my 2001, they worked like a charm on the stock turbo, with the tuning i had it was somwheres around 350rwhp. the trurbo would get up around 34 35psi so i dont know how long it would have worked but i drove it pretty hard for about 6 or 7k miles before i sold it. BTW those boost pressure blew my stock hg...fyi
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #4 of 22 (permalink) Old 01-13-2010, 12:51 AM Thread Starter
Were your heads stock and never off the block or did you reuse stock bolts?
post #5 of 22 (permalink) Old 01-13-2010, 03:08 AM
Busy Busy
Marty's Avatar
You do not reuse stock head bolts when reinstalling the head and I don't believe the turbo will live for long.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 22 (permalink) Old 01-13-2010, 04:04 AM
TARM's Avatar
I thought the stock turbo was hardly enough for the stock injectors.
TARM is offline
post #7 of 22 (permalink) Old 01-13-2010, 03:14 PM
jaybuller's Avatar
mine was a fresh full rebuild, with new headgaskets and new headbolts. it only had about 2000 miles on it when it blew the headgasket. it would have blown it sooner but i babied it till then. i studded it and never hsd another problem with it. i also changed to forged rods but not sure if that was nessisary or not.
post #8 of 22 (permalink) Old 01-13-2010, 04:44 PM Thread Starter
Why would the turbo not live long? Is it from boosting past the 25psi? Could I limit the wastegate to 25psi or would that really limit the performance of the injectors? I really do not want to upgrade the turbo, but don't want the an unmatched set up either.
post #9 of 22 (permalink) Old 01-13-2010, 05:05 PM
rebelchevy02's Avatar
Ive been running that combo for about 20k miles. I try not to flog it too hard. Its a truck I work out of. Just havent put a turbo on it yet. Seems to be ok for DD purposes. WOT is were you notice its not enough turbo.
DRW and tow fast parts.......
rebelchevy02 is offline
post #10 of 22 (permalink) Old 01-13-2010, 05:11 PM
Getting Faster...
Izzy351's Avatar
I'm running the van turbo (essentially a stocker with 1.15 exh housing) with my hybrids and it ain't enough. With those singles a van turbo would be okay. 1.0 housing might get you by, but if you are hammering it at 35psi (what I'm doing to my van turbo), I'd bet it won't stay together too long.
Izzy351 is offline
