is gutting the EBPV worth it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 01-12-2010, 09:57 PM Thread Starter
clutzmi's Avatar
Question is gutting the EBPV worth it
mine is constantly getting stuck closed so im toying with the idea of gutting it but is it worth it, or should i just fix it. i would like some pros and cons along with some opinions about it
thanks in advance
Clutz
97 F250 OBS 7.3 Turbo Diesel 4X4, ISPRO gauges (boost, pyro, trans temp), Boost fooler, BB mod, Custom DIY cold air intake, CCV mod, 3" Diamond Eye down pipe, 4" exhaust, no cat, no muffler, Fog Lights, wheels and 285/75/16 tires
clutzmi is offline
post #2 of 16 (permalink) Old 01-12-2010, 10:01 PM
mnstroker's Avatar
Re: is gutting the EBPV worth it
Gut it then you dont have to worry about it getting stuck ever again.
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #3 of 16 (permalink) Old 01-12-2010, 10:44 PM
TRX370r's Avatar
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #4 of 16 (permalink) Old 01-12-2010, 10:53 PM
Gut it, or for about 100 bucks you can buy a non ebpv pedistal and been totally done.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #5 of 16 (permalink) Old 01-12-2010, 11:11 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
my buddy just paid around 165 i believe to rebuild his cuz hes a dumbazz and thats with the discount he gets because his company does so much buisness with ford
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #6 of 16 (permalink) Old 01-12-2010, 11:16 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Unplug it and wire it.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #7 of 16 (permalink) Old 01-12-2010, 11:42 PM
jaybuller's Avatar
i would pull it off and replace with the non epvb. looks better, no chance of leaks out of the pluged hole. but if you dont want to spend any money yes just do the delete mod.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #8 of 16 (permalink) Old 01-13-2010, 04:14 AM
TARM's Avatar
I would think this is the best solution based on everything I don't know.
TARM is offline
post #9 of 16 (permalink) Old 01-13-2010, 04:16 AM
Don't EFN worry about it
Aljay's Avatar
Do it yourself and learn. Its not real hard.
Tuned by T Wildman
Aljay is offline
post #10 of 16 (permalink) Old 01-13-2010, 04:18 AM
blacksmokingplumber's Avatar
Newbie question here but is the ebpv why mine seems to lug a little like i just tugged tight on a load at funny times at low RPM and the pop right up with a little tap of throttle.
2001 F-250 SC/SB 4x4 Auto
"All I want to do is Burp, Puke and Fart, In that order."
"Powerstroke Performance Headquarters!"
blacksmokingplumber is offline
