Street driven p-pumped 7.3, what turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-12-2010, 04:56 AM Thread Starter
Moulder's Avatar
I know when you spend the money to get the parts to p-pump a 7.3 you wouldn't expect someone to run it on the streets. I am going to put it back together with a stock short block with forged rods. The pump has been rebuilt to stock specs before I bought it and only has either 7 or 8mm plungers but has the nice quick fill cam. I also installed a 5000 rpm gsk and adjustable fuel plate. With the plate slid all the way forward it only puts out 210cc's of fuel. I don't have injectors for it yet either. Since I cant mount a turbo in the stock location I have been thinking about getting something different to use. Is there a turbo on a semi that would be good to use on this? I would perfer something cheap and easy to find for now. When I get tired of tinkering and think I am comfortable with making adjustments on it the pump is going to be sent off and the short block built.
Moulder is offline
post #2 of 11 (permalink) Old 01-12-2010, 05:12 AM
theSLEEPER's Avatar
Re: Street driven p-pumped 7.3, what turbo?
Budget?
theSLEEPER is offline
post #3 of 11 (permalink) Old 01-12-2010, 05:20 AM
Village Idiot
southmike's Avatar
Really depends on injs and how much fuel your pumping.
If it is a pee trickle vs ol faithful.
My uneducated guess would be base it on est hp.
Choose the turbo that supports that.
Turbos donlt care what is powering the injectorsl just how much fuel.
southmike is offline
post #4 of 11 (permalink) Old 01-12-2010, 06:17 AM Thread Starter
Moulder's Avatar
Originally Posted by theSLEEPER View Post
Budget?
Right now it is just get it running, get use to it, and have fun. This isn't a daily diver and I'm trying to make this a learning project (be it good or bad). I don't want to spend a ton on a turbo that i will out grow when I get the pump built and have a lot of fuel. I am just looking for a junkyard turbo that would be usealble with the fuel I have now.
Moulder is offline
post #5 of 11 (permalink) Old 01-12-2010, 07:09 AM
Do you want to stay with a single charger? Or possibly go with twins in the future?
bigjake0524 is offline
post #6 of 11 (permalink) Old 01-12-2010, 03:57 PM
Myles_S's Avatar
210cc's hmmm..... would a GT42 or something similiar be sufficient?
I may be way off track here, just thinking by the amount of fuel he says he's pushin
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #7 of 11 (permalink) Old 01-12-2010, 04:47 PM Thread Starter
Moulder's Avatar
I think a single for now for simplicity, if I could a find a set of turbos that would work together I might be interested in doing twins. My plans are just to have fun now with cheap stuff and then when I have the pump and engine built have a nice set built up.
Moulder is offline
post #8 of 11 (permalink) Old 01-12-2010, 05:12 PM
Lovin the Tuna
RedSmokey's Avatar
Thats kinda what i was thinking...
But im just a know-nothin window licker...
2001 F250
2000 F250
RedSmokey is offline
post #9 of 11 (permalink) Old 01-12-2010, 10:49 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
If it wont fit in the stock location, will it fit on top of the engine at all? Is this going in a superduty with a hood? Not really many places to put the turbo except under the wiper cowl on top of the engine unless you make custom headers towards the front.
Stock
PowerstrokeJunkie is offline
post #10 of 11 (permalink) Old 01-13-2010, 12:58 AM
What else?
smokyred's Avatar
You could mount the turbo on the passenger side where most people put their atmosphere turbo for twins. Moremph is running his single there.
My guess for a charger would be a 42 or a S471 or S476. It really depends on your rpm and the amount of fuel you can put in the cylinders.
Dave
smokyred is offline
