Turbo decision - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 01-11-2010, 02:48 AM Thread Starter
Turbo decision
My truck doesn't have upgraded injectors, and at this time I don't want to upgrade my injectors till I build the bottem end. Having said this, I need to replace my turbo soon since its the original and I don't want to have it blow without something here to put in it right away.
Would it be a waste of money to upgrade to a 38R or a H2E without injectors? I want to do something more than just rebuild my stocker. All opinions are welcome.
02 F250 PSD 7.3L
Tymer,Irate T4 mount with S366 Turbo, 5in SP,triple gauge pod w\ Di-Pricol Optix (EGT,Boost,tranny temp)
CCV Mod, In-tank mod, Harpoon mod, Airdog, ITP regulated Return (8LL replaced with AD)
Oilguard Bypass Oil System
Dieselsite Coolant Filter, Fluidampr
ITP boost Annihilator, BTS Trans and T.C.
DP tuner 6 position
02powerstroke is offline
post #2 of 31 (permalink) Old 01-11-2010, 02:57 AM
Ticking time bomb
Re: Turbo decision
gEt a38r
groomzybanshe is offline
post #3 of 31 (permalink) Old 01-11-2010, 03:20 AM
TARM's Avatar
Re: Turbo decision
It depends where you ultimate goal is. Where are planning on taking this build? HP? What Injectors when you do get them?
TARM is offline
post #4 of 31 (permalink) Old 01-11-2010, 03:26 AM
<-- GO BRONCOS
dblamp's Avatar
Re: Turbo decision
The 38R will work fine with stock injectors.
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #5 of 31 (permalink) Old 01-11-2010, 01:47 PM Thread Starter
Re: Turbo decision
As for right now, my truck will always be a DD... I don't want to lose the reliability of the truck. I do want to do a HPOP in the future, but as far as injectors, they will always be stock if not just slightly bigger. My truck won't be putting down monster HP anytime soon.
02 F250 PSD 7.3L
DP tuner 6 position
post #6 of 31 (permalink) Old 01-11-2010, 01:50 PM
The Fireman
big_stroker's Avatar
Re: Turbo decision
38r would be perfect for you.
big_stroker is offline
post #7 of 31 (permalink) Old 01-11-2010, 01:56 PM Thread Starter
Re: Turbo decision
I looked at the H2E because of the fact that you change the mount style and woudl be helpful for future modifications if I did end up going bigger. Would a H2E with stock injectors be a joke?
02 F250 PSD 7.3L
DP tuner 6 position
post #8 of 31 (permalink) Old 01-11-2010, 01:56 PM
Busy Busy
Marty's Avatar
Re: Turbo decision
I'd get a stock H2E... it's smaller then a 38r, cheaper and it's a mounting kit you can expand on when you buy the built bottom end.
I'd call Carson for his mount kit, I really like his up-pipe setup over hypermax's...
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #9 of 31 (permalink) Old 01-11-2010, 01:57 PM
Busy Busy
Marty's Avatar
Re: Turbo decision
A stock H2E or a modded 66mm H2E runs great on stock injectors.
Elkton, Maryland
Marty is offline
post #10 of 31 (permalink) Old 01-11-2010, 02:06 PM Thread Starter
Re: Turbo decision
Not sure I know who Carson is. I frequent the forum, but only know a few suppliers.
02 F250 PSD 7.3L
DP tuner 6 position
