99.5 wanting to get a chip - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-11-2010, 01:15 AM Thread Starter
mjones's Avatar
I looked at the computer and the code is i think mrt1 anyone know much about this any good reccomendations on a chip i have a dp tuner on my other truck and seems to be great thanks
1999 f 350 ext cab racer x tc and valvebody dp tuner 60tow 80e 120race 140 extreme 04 grand cherokee
1999.5 f350 crew cab beans tunes
mjones is offline
post #2 of 11 (permalink) Old 01-11-2010, 01:19 AM
Thomas7.3psd's Avatar
Re: 99.5 wanting to get a chip
go with [email protected] gearhead automotive and be done.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #3 of 11 (permalink) Old 01-11-2010, 03:16 AM
PHPDiesel's Avatar
That PCM code sucks. On the bright side, any custom tuner you speak with is going to send you a PMT1-based chip unless you specify otherwise.
At least you have a good PCM family (DPC 422).
Cody
PHPDiesel is offline
post #4 of 11 (permalink) Old 01-11-2010, 12:10 PM Thread Starter
mjones's Avatar
yeah never heard of mrt1 i think this was a canada truck before it came to the usa
mjones is offline
post #5 of 11 (permalink) Old 01-11-2010, 12:44 PM
NEVRNF's Avatar
I believe MRT1 is the same DPC family as the PMT and NVK. Pull the pcm out and check on the tag for the DPC #. If it is then a PMT program will work on it.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #6 of 11 (permalink) Old 01-12-2010, 05:58 AM
tbolt's Avatar
I have an early 99 with an xle4 and jody @ dp has my truck running really good. I'm very happy with the dp.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 11 (permalink) Old 01-14-2010, 03:56 PM Thread Starter
mjones's Avatar
pulled tag it reads xu2f-rb npef 008301 MRT1
mjones is offline
post #8 of 11 (permalink) Old 01-14-2010, 06:57 PM
PHPDiesel's Avatar
So get yourself some tunes already!!
Cody
post #9 of 11 (permalink) Old 01-14-2010, 07:20 PM
BDP Tuner's Avatar
yes you are right about the codes on the computer it can be set up with PMT tunes. I have dyno proven PMT1 tunes and will be happy to help any way I can
BDP Tuner is offline
post #10 of 11 (permalink) Old 01-14-2010, 09:44 PM
tbolt's Avatar
What are you going to do with the truck? Makes a diff when tuning.
Glen
tbolt is offline
