What do you think is going on? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-09-2010, 03:24 AM Thread Starter
lildevil02's Avatar
Send a message via AIM to lildevil02
Quick history on the truck. Stock motor 253, xxx miles. DI Mini Me's Fass 150/180 DI RR H2E BTS tranny.
Truck is running ok but not @ 100% it feels like it down on power some although I really canít figure out why. I notice while cursing on the hwy it fine but when I roll into to pass someone itís like the motor shutters for split second and then goes. It never this so I hooked it up to AE tonight and this is what I got.
P1277- Cylinder 7 high to low side open
P1298- IDM Failure
P0605- Internal Control Module Read Only Error.
Ran a cylinder contribution test
P0266-Cylinder 2 circuit contribution/balance fault.
I also data logged a short run let me know if you think posting it will help.
lildevil02 is offline
post #2 of 5 (permalink) Old 01-09-2010, 03:26 AM
Banning Smut
PTSUPERD's Avatar
Re: What do you think is going on?
Bad uvc harness / connection?
PTSUPERD is offline
post #3 of 5 (permalink) Old 01-09-2010, 03:27 AM
Laces Out
bigrpowr's Avatar
pull the valve cover and check the connection to #7. its on the passenger side 2nd to last towards the firewall. seems like an electronic issue. run a buzz and a contribution test as well.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 5 (permalink) Old 01-09-2010, 03:32 AM Thread Starter
lildevil02's Avatar
I was leaning toward that, but I'm not 100% sure.
Ran a buzz tests everything is some what normal, a few injector sounded weaker than others. I'll run another in tomorrow and narrow it down but there are 2-3 injectors that buzzed really quietly, While the other were a lot louder.
post #5 of 5 (permalink) Old 01-09-2010, 03:34 AM
All done now
Arisley's Avatar
Sounds like injector issues. A buzz test means the electronic side of the injectors.
Arisley is offline
