Diy napa fuel system. need answers ASAP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 55 (permalink) Old 01-04-2010, 11:01 PM Thread Starter
TRUBBS's Avatar
I'm on my phone so please bear with me
So I went to napa to pick up the parts are needed to relocate my fuel filter onto the frame rail. I got the mount pt-number 4770 and the water Sep. Pt-number Fs1212 without a problem. Then I went to get the 2 micron filter fs5320 and the guy told me their was no such filter and they only had filters down to 10 microns and that was the lowest. So I just bought it (already been their for an hour dealing with the first guy telling me not to change filters or I was gona ruin my motor, and was late for work) now can I use that filter or do I need to go find a 2 micron elsewhere?
Another dumb question but I'm on my phone and it don't show pictures but I'm guessing I needed to buy 2 filter bases right? Or is their one that holds both filters?
TRUBBS is offline
post #2 of 55 (permalink) Old 01-04-2010, 11:07 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
Re: Diy napa fuel system. need answers ASAP
Idk about the 2 micron filter but yes you will need the 2 filter bases havent seet one that has both and typically you mount on right before the pump and one right after
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #3 of 55 (permalink) Old 01-04-2010, 11:08 PM
jimdawg185's Avatar
I think that the stock is 10 micron. 2 is def better though.
I think that you can get them with two but I don't know for sure.
jimdawg185 is offline
post #4 of 55 (permalink) Old 01-04-2010, 11:09 PM
I am using napa water separator 3405 pre pump which is 12 micron and then 3528 post pump which is 2 micron.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #5 of 55 (permalink) Old 01-04-2010, 11:11 PM
A Ghost these days...
farm boy's Avatar
2 Micron NAPA 3674, WIX 33674, Fleet Guard FF5319
These are the different filter part numbers for a 2 micron filter that will fit the base that you have.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #6 of 55 (permalink) Old 01-04-2010, 11:15 PM
TARM's Avatar
Napa 2 micron Fuel Filter - 3528 is what I have found. That is what Marty has listed as his 2 micron on his DIY fuel system
TARM is offline
post #7 of 55 (permalink) Old 01-04-2010, 11:19 PM
I just looked both up on the napa site. I think 3674 is just a longer/taller version of the 3528. Both 2 micron. I am assuming the 3674 should last longer between changes?
rpm-inc is offline
post #8 of 55 (permalink) Old 01-05-2010, 01:23 AM Thread Starter
TRUBBS's Avatar
Thanks for all the fast replys! And thanks for giving me the correct part number for the 2 micron
TRUBBS is offline
post #9 of 55 (permalink) Old 01-05-2010, 06:18 AM
TARM's Avatar
What is sad is that their own employee could not do the same even with the inventory and description computer right in front of him.
TARM is offline
post #10 of 55 (permalink) Old 01-05-2010, 06:31 AM Thread Starter
TRUBBS's Avatar
yeah i know, i was already irrated from the lecture i got from the "filtration expert" about howim gona runin my truck i just wanted out of their before i lost it
TRUBBS is offline
