stage 2s and a stock sd turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-04-2010, 07:34 PM Thread Starter
smokin stroker
I have a brand new engine in my 95 I put a intercooler on and a sd turbo while it was out I want to run stage 2 diy injectors and a addrenalin e hpop but I dont know if the sd turbo can take it what do you think
strokedeis is offline
post #2 of 13 (permalink) Old 01-04-2010, 07:37 PM
woodduck97's Avatar
Re: stage 2s and a stock sd turbo
I dont think it will hold to long if you go running it hard. If you got a SD turbo on there now why not just go ahead and get the 38r?
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #3 of 13 (permalink) Old 01-04-2010, 07:40 PM
Pulling sled for hire
ParkerFly's Avatar
Good tunes that don't dump a ton of fuel into the engine at low RPMs will help, but it's still a matter of time if you use the power at all.
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #4 of 13 (permalink) Old 01-04-2010, 07:52 PM
woodduck97's Avatar
Mine didnt last 4,000 miles and I was easy on it. Then i ran it one time after I got the boost fooler and it was done lol
post #5 of 13 (permalink) Old 01-04-2010, 07:52 PM
The Fireman
big_stroker's Avatar
If the turbo is in good shape and you have good tunes you should be ok for a while. I would say go for a 38r since you already have the SD stuff.
big_stroker is offline
post #6 of 13 (permalink) Old 01-04-2010, 07:57 PM
Death Row Inmate #7
strokin'_tatsch's Avatar
the stock SD turbos aren't even too great for running with a chip and stock injectors. LoL. the start surging real bad and everything.. just not something i like, but you could put in an OBS compressor wheel and see if that helps it. my buddys stock E99 turbo held for about 4 months with his DIY stage 2's then we pulled it and the thrust bearing was almost worn all the way through and the compressor wheel was hitting the housing. when we put the stage 2's in the truck that turbo was all but brand new. it was in perfect shape with no knicks in the wheel and NO shaft play. LoL. it didn't last long at all.
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
post #7 of 13 (permalink) Old 01-04-2010, 08:17 PM
TRX370r's Avatar
Key to making them last is putting a 1.0 exhaust housing and you can use a wheel or a anti surge housing on them. keeping the boost in check any they will last a while. Beans does it all the time and its a nice combo for the $. IMO
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #8 of 13 (permalink) Old 01-05-2010, 12:33 AM
Dead Member
Marauder's Avatar
20,000+ on mine as setup as above along with a wheel and ATS housing. Run it 8 to 10 hours a shot towing. Freeway speed and in town driving. Tunes are consertive at 371/730ftlbs. Good mileage too. Stock 17* hpop.
2001 F350 7.3 SD EC LB 4X4 Handshaker, Water/Meth Injection, GQSSB W/Carson Stauffer mount, Swamps 250/200 injectors, TE Duals, Fuelab/Sump, Spearco, FS 2500, Fluid Dampner, ARP head/Main studs, Sinister R/R, Detroit locker out back, etc.
Marauder is offline
post #9 of 13 (permalink) Old 01-06-2010, 12:44 AM
Buffalo Diesel
What kind of PSI are you guys running the stock turbo to? I must have hit almost 40 today... gauge swung to 35 so quick I couldn't get out of it before it was pegged. Getting my new tunes tomorrow.
Jack_Toepfer is offline
post #10 of 13 (permalink) Old 01-06-2010, 03:18 AM
TRX370r's Avatar
Bean told me no reason to push it over 30 cause its pretty much out of the map there.
Thomas Jefferson
TRX370r is offline
