Lets see your water/meth set-up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 01-03-2010, 08:32 PM Thread Starter
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
Im looking for pictures or how yall have em set up.
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #2 of 26 (permalink) Old 01-03-2010, 09:32 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Lets see your water/meth set-up
What do you want to see? Tanks in the tool box, pumps on the frame rail, injectors in the IC pipes...
Joe
CSIPSD is offline
post #3 of 26 (permalink) Old 01-03-2010, 09:36 PM Thread Starter
i im interested in the entire set-up really not just one part in particular.
post #4 of 26 (permalink) Old 01-03-2010, 09:38 PM
CSIPSD's Avatar
Water Injection, Methanol Injection, Alcohol Injection Systems | Coolingmist
The best water injection systems on the market...
Other then a full competition set up which require pump lube and such.
Joe
CSIPSD is offline
post #5 of 26 (permalink) Old 01-03-2010, 09:57 PM Thread Starter
I remeber garret awhile back talking about some kind of anti-corrosion additive what exactly is the additive?
post #6 of 26 (permalink) Old 01-04-2010, 12:01 AM
there is an oil you up in to keep water from freezing
USAF TSGT Retired "Medically"
99.5 CCSB 4x4 built motor and BTS
99.5 EX Cab Long bed with mild mods and BTS
Big thanks to Swamps Diesel and BTS!!!
randylamarr is offline
post #7 of 26 (permalink) Old 01-04-2010, 01:10 AM Thread Starter
whats it called and where do yall get it
post #8 of 26 (permalink) Old 01-04-2010, 01:45 AM
<< wasted fuel >>
haulin99sdp's Avatar
haulin99sdp is offline
post #9 of 26 (permalink) Old 01-04-2010, 02:25 AM
TARM's Avatar
Does Coolmist offer anything that has two sep stages like the Snow STAGE 3 MPG MAx has? I know the Coolmist pumps are huge step up from Snow's but I am wanting to go with small nozzles flow whats needed while normal driving and then when I put hammer and PSI and EGTs got to spike the large nozzles kick in.
What I was thinking about was using the Coolmist pumps with the Snow controller etc. Would that work?
I would go all Coolmist if they had a system that can do the same. I also really like that the Coolmsit controller fits in the standard guage bezel holes
TARM is offline
post #10 of 26 (permalink) Old 01-04-2010, 03:38 AM
PSN Pretender
907DAVE's Avatar
I am pretty sure that's how all the stage 2 kits work, progressively increase pressure until reaching max boost or egt's and then they are WFO.
907DAVE is offline
