Gauges finally installed..question? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-02-2010, 05:27 PM Thread Starter
I finally get my gauges installed, thanks KT Performance, and I have a question? What is the norm for boost witha PHP chip on say the 100HP perf, and the 85DD settings? Also, how long does it take the tranny to move off 100 degrees in 30 degree weather, or will it? The factory dummy gauge moved up near where it normally stays.
2002 F250 CC 4x4
Tommy69Z28 is offline
post #2 of 12 (permalink) Old 01-02-2010, 05:28 PM
PSN Mega Miler
crowz's Avatar
Re: Gauges finally installed..question?
Well mine hits 21 psi instantly when I get on it with the 85DD setting from PHP.
Its like it runs into a wall and doesnt go up anymore so thats the wastegate or something kicking in.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 12 (permalink) Old 01-02-2010, 05:30 PM Thread Starter
I seen 21-22, on 85DD, and 24 on 100Per, I was surprised my pyro was right at the red line though
2002 F250 CC 4x4
post #4 of 12 (permalink) Old 01-02-2010, 05:42 PM
PSN Mega Miler
crowz's Avatar
Mine redlined the pyro too.
But damn it gets up and goes though
crowz is offline
post #5 of 12 (permalink) Old 01-02-2010, 07:18 PM
Metal - It kicks your ass
As for your trans temp guage. Mine does'nt move at all. About 100-110 in 20 degree wheather here.
I've been told your trans temp will only be approximately 70* over ambient air temperature. If you want to see if its workin at all then drive it like hell until your guage starts movin.
And to back up CROWZ., in my Street and Race tune im max out at 21 psi. I've never seen more. Like he said, it just hits a brick wall.
Modded L99
dirtboy25 is offline
post #6 of 12 (permalink) Old 01-03-2010, 04:30 PM
tbolt's Avatar
The truck in my sig will hold 23-24 psi in a 40 tow setting with my dptuner with egt's around 1300. Now thats with a 12K lb toyhauler on it.
Trans temp should be 70-80 above ambient.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 12 (permalink) Old 01-04-2010, 12:50 AM
Buffalo Diesel
I think your boost numbers will depend on your exhaust. When I removed my muffler I gained 2psi (to 18). With my DP Tuner the truck makes 27psi.
Jack_Toepfer is offline
post #8 of 12 (permalink) Old 01-06-2010, 06:29 PM
littlemike5889's Avatar
I just hit 30psi yesterday with my dp tuner set at 140. My gauge only goes up to 30 so im thinking it might be time for a new gauge.
99 F-250 w/ 6spd manual Dp-tuner, mbrp exhaust, air intake, south bend dual disc clutch, boost fooler
littlemike5889 is offline
post #9 of 12 (permalink) Old 01-07-2010, 01:20 AM
My PHP 60 tow tune easily hit 22psi and never touched 1000F on the pyro.
Haven't had time to play with the others yet, other than watching the 140 spool the turbo to 26+ faster than I though they could...
With a stock turbo, most tunes should keep the pressure under 25psi.
1999.5 F350 SuperCab, Auto, 4x4, 3.73, PHP tunes, PI Stallion, Tri-something-olator, Hutched/Harpooned, 6637, CCV, IAH delete, MBRP 4", Evans, 203 T-stat, Japanese drain valve, dyna-beads, 70K
two-rocks is offline
post #10 of 12 (permalink) Old 01-07-2010, 02:11 AM
Village Idiot
southmike's Avatar
there is a defuel setting that kicks in unless you have a boost fooler or your tuner programed around it
southmike is offline
