More Fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 01-01-2010, 01:39 AM Thread Starter
JHill's Avatar
More Fuel
want more.
Nozzle only or machine the pistons more and nozzles? 238/100%. No bigger than 250cc I stiil need to be able to tow with this truck,
Different charger in the works as well S400 T-6?
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #2 of 21 (permalink) Old 01-01-2010, 03:50 PM
The Fireman
big_stroker's Avatar
Re: More Fuel
what kinda power are you looking for?
big_stroker is offline
post #3 of 21 (permalink) Old 01-01-2010, 04:53 PM Thread Starter
JHill's Avatar
Re: More Fuel
500ish, big stroker ever checked backpressure # on your setup?
I see your dyno #'s and they look good,,. on my dyno run a year ago my torque # was 28ftl bs higher and a 100 hp less - wich concerns me or the dyno I ran on whas not accurate?
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #4 of 21 (permalink) Old 01-01-2010, 05:28 PM
Re: More Fuel
Step up to the plate....
bigjake0524 is offline
post #5 of 21 (permalink) Old 01-01-2010, 05:29 PM
Re: More Fuel
Oh yea, Happy F'n new year!
post #6 of 21 (permalink) Old 01-01-2010, 05:38 PM
Lovin Life...
02BigD's Avatar
Re: More Fuel
238/100%. Throw a modded h2e on and you are all set. Maybe an adrenaline pump if your Hpop is tired.
In regards to the torque vs hp, what RPM did you reach that at? If it's low in the curve, you may want to talk to you tuner.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #7 of 21 (permalink) Old 01-01-2010, 06:30 PM Thread Starter
JHill's Avatar
Re: More Fuel
peak torque 2100rpms peak hp 2500
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #8 of 21 (permalink) Old 01-01-2010, 08:21 PM
Custom Trailer Sales
TrailerHauler's Avatar
Re: More Fuel
Where those graphs your 200cc's and d66 setup?
Also how hot did that combination get while towing?
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #9 of 21 (permalink) Old 01-01-2010, 08:38 PM
Re: More Fuel
That is on his current set up, minus the fuel system upgrades.
post #10 of 21 (permalink) Old 01-01-2010, 08:54 PM Thread Starter
JHill's Avatar
Re: More Fuel
yes they are. Towing 10k in the 120r tune is managable as long as the r's are up. on the dyno the egt's were off the gauge.
27lph nozzles are on now, If I go to a 40ish lph nozzle that would be close to a 100% over correct?
the D66 so far had been a great turbo for pulling, on the street in the 120 tune it will surge easily in 5th and OD if less than 2k rpm's
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
