the good and bad of a 4"DP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 12-31-2009, 12:26 AM Thread Starter
just a welding fool.
Hawker's Avatar
what are your guys thoughts on a 4" downpipe over the stock one? Is it such a small piece that it's almost not noticable?
on top of that, many swear that a 4" exhaust is plenty. would a 5" be just for sound?
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #2 of 15 (permalink) Old 12-31-2009, 02:10 AM
TARM's Avatar
Re: the good and bad of a 4"DP
From what I saw you definitely get a EGT drop.
How it helps is on a curve based on power upgrades.
As stock not much at all
Add a chip and you get more benefit
Add A turbo even more
Add new injectors even more.
It and the muffler are the two biggest restrictions.
That is why IMO its best to jsut upgrade the whole exhaust as otherwise you are only moving the point of restriction.
First is the OEM muffler next the down pipe finally the exhaust tubing. But when you consider the time and $$ of swithcing only the first two you really could have done the whole thing for only a bit more $ and time.
TARM is offline
post #3 of 15 (permalink) Old 12-31-2009, 02:17 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
i jus put a 4" dp and 5" the rest of the way on my tow rig. i am loving it so far. have not towed but def. runs cooler and cools down faster. there is no bad side.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #4 of 15 (permalink) Old 12-31-2009, 02:58 AM
Myles_S's Avatar
I've got a 4" dp in my 5" system. EGT's stay about ~600* on the highway.
5" isn't needed at moderate power levels but what the heck it sounds good. Some may even report losing low end power...I didn't notice, did notice the higher topend though.
Unless your pushing BIG BIG numbers 5" isn't needed
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #5 of 15 (permalink) Old 12-31-2009, 06:15 PM
Catfish Mafia
li'l tugger's Avatar
Send a message via Yahoo to li'l tugger
my first exhaust mod was a muff delete.. a little gain and cool sound. then i did a 4" DP and even more gain. i think with more upgrades, the DP is more important, but i did notice a jump with just a chip. i now have 4" pipe from the turbo to the wheel with 3 bends in between. i think this is plenty for most of us!
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP,
13.94 @ 96.9mph.. on stock turbo
li'l tugger is offline
post #6 of 15 (permalink) Old 12-31-2009, 06:31 PM
Pennsylvania Coal Roller
ben02stroke's Avatar
I have the same system (got a stainless mandrel super cheap on ebay) I love it, another fourm I read awhile ago said the same thing you may lose a little low end with a 5 inch but it is not even noticeable and plus if you want to do powerup grades you already know that you wont have to worry about upgrading your exhaust system. Plus the 5 inch sounds and looks way cooler.
2001 F-250 7.3 auto rclb xl trim all stock with a Fisher MM2 7.5' plow, work in progress
2015 RAM 3500 cclb 6.7 cummins auto all stock grocery getter
2008 F-350 cab and chassis w/ 9 foot reading service body 6.4 stroke ,auto, all stock GVW 11,500 all day every day 222,xxx and some how its still on the road!
ben02stroke is offline
post #7 of 15 (permalink) Old 12-31-2009, 06:35 PM Thread Starter
Hawker's Avatar
i ran a 4" straight right when i got the truck, but the 450 needs a different bed then what the 250/350 systems give you. I was able to make it work, but if i end up going with a 5", i may either turn it out before the tire, or run a single stack. not sure yet, but i wanted to see what guys were saying after moving to a 4" DP.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #8 of 15 (permalink) Old 12-31-2009, 08:04 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
After ditching my stock DP My egts stayed cooler and cool of faster than before. Im running a 4'' DP to full 5'' system.
SMOK'N BLUE STROKER is offline
post #9 of 15 (permalink) Old 12-31-2009, 08:42 PM
Mtack's Avatar
Exactly!
Matt
E99 F350 ECSB SRW 4x4 ZF6 3.73 Adrenaline HPOP, chip, tymar
Mtack is offline
post #10 of 15 (permalink) Old 12-31-2009, 10:02 PM
NevrKnow's Avatar
I'm with these guys. And are you really going to save any $ not getting the DP with your new exhaust? To me it seems like reusing old seals on a new fuel filter, you can, but whats the point?
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
